Not sure if it should be a proposal, I’m from Vietnam and can buy GRIN from Poloniex buy USDC without any issues. In case you need help, I could buy GRIN for you.
If Grin++ wallet doesn´t work for you for now, use Niffler wallet instead.
Works perfect for me and it´s super easy. I use “receive via Hedwig” to get my Grin.
Niffler wallet has a hedwig v1 relay service , which enable User without public ip receive grin really easy
In other words, You could withdraw grin from any exchanges and miner pool effortlessly .
Hi, I have the Following error message everytime I restart the wallet. What should I do to fix it pls? (I have looked on several forums (GitHub and this Grin Forum but I Don’t find the solution). Thx !
Delete : %userprofile%/.GrinPP/MAINNET/NODE
Then re-open your wallet and you should be back in business.
Just tell me at least one wallet that works with Grin
grin-wallet, Grin++, Niffler, ironbelly, vite, wallet713…
There are no wallets. We are all just LARPing.
I have found Niffler very user-friendly and robust.
I would like to thank you because it works perfectly now that I have followed your recommendations.
Thank You! This worked for me also for v0.6.4. Must re-download chain but it works.
Delete: %userprofile%/.GrinPP/MAINNET/NODE
@david Hi. Just updated from 0.6.4 to 0.7.1 on Mac. Full sync with all outputs.
I’m having problems Receiving Files. I uploaded file sent from pool. When I hit receive button, 0.7.1 flashes white and goes back to User-specific wallet home. I have tried with two different pools and tried turning off TOR feature.
does tx file need to be in special format now? Could my pools be using an pre-hardfork-compatible tx format? Thank you
It should support pre-hardfork and post-hardfork slate files. I do most of my testing on windows, so perhaps I broke the mac version. I’ll investigate and get back to you.
OK, thank you for quick response.
One last bit of info. I used Inspect tool and noticed a React-Hot-Loader error saying:
misconfiguration detected, using production version in non-production environment
Warning: Each child in a list should have a unique "key" prop.
Thanks for the info. You’d be surprised just what you could find inspecting the frontend. Everytime I update dependencies, I get 100 new warnings to deal with. A lead UI dev is desperately wanted. The job pays nothing, but has really cool perks like endless support questions. Let me know if you know of anyone interested
There is an issue with receiving on mac. I’ll get a fix out today.
The Wallet is nice, It’s a great step in the right direction, really good first step.
If Grin wants adaptation and decentralization they need a gui miner.
Grin will have to be easy to mine before it becomes mainstream.
is this the issue?
No. That’s different. I’m releasing 0.7.2 now. Once it’s out there, delete ~/.GrinPP/MAINNET/NODE and install the new version
I deleted it, I have 3 other grin wallets that work
For this issue, try closing app from the red X on the window rather than cmd+q or topbar for entire app. If that doesn’t work delete /NODE folder
