Selling the source code of a Node.js script that automates bidding and Grin mining at Vast.ai instances. Enables you to bid cheap GPU instances for cloud mining.
Features:
- C29 and C31 mining
- Auto-bidding
- Auto deleting of stopped instances
- Auto outbidding if less than max
- Auto configs the GPU instance via SSH when the instance is started.
- Can be configured in any pool.
- Only compatible with “grin-miner” rigth now.
- Stop bidding more instances if surpasses daily USD limit
- Configurable daily USD and percent profit (Can be positive or negative, if you want to outbid.)
- Automatically calculates GPU costs and apply a % as max bid. For example:
RTX 2080 Ti generates 0.05 $ per hour. Set maximum percent profit to 10%. The script will bid instances for 0.045 $
Price: 1 BTC . Accept other crypto like Grin or ETH.
Installation in your server/vps included. Linux server only.
DM me if you are interested.
PS: If this is not the correct category, please point me out to the right one. Thanks!
PS2: Instead of selling one license for 1 BTC. Would you like to use this software with devfee?. Supporting Grinminer Fair license.
