which pole should I use and which wallet should I use to receive
Here is a list of mining pools and exchanges:
hub/mining-exchanges.md at main · grincc/hub · GitHub
Currently grinmint has the lowest mining fee and has as benefit that it supports slatepack messages for withdrawal.
You can use any wallet you like:
I’m using gaeapool , withdraw by slatepacks smoothly in 3 seconds.
