Hello!!
I’m using Niffler Wallet, but it seems that the Wallet address is NOT reachable. So, which wallet can I use?
Thanks
Gustavo
Hello!!
Thanks
Gustavo
Grin++ is the best choice, IMO
Thanks!! And the address is reachable? Because the others uses “Satlepack” address?? or something like that…
You can check if your address is reachable here:
https://grinnode.live/tools/wallet-checker
You have to keep your wallet open while you want to receive a transaction
Thanks Axon7!!
What if the wallet is closed? When I open it, maybe another day, the coins will arrive?
Your wallet must be online to talk to the node while mining, if you are solo mining. If you are mining with a pool, then your wallet just has to be online when you withdraw from the pool.
This post was flagged by the community and is temporarily hidden.
