Wallet and node different machines, same network
hi,
how do I use grin-wallet with a node running from a different machine on the same network?
from what i understand if connecting to a remote node i would type:
grin-wallet -r http://some_address:3413 info
can i instead do something like:
grin-wallet -r 192.168.0.33:3413 info ?
thanks
Sure, you can use remote GRIN API calls, for example like this using our free and public API you can use for free:
CLI:
./grin-wallet --api_server_address β€œhttps://grinnode.live:3413”
or add this to your grin-wallet.toml file for permanent usage
grin-wallet.toml :
check_node_api_http_addr = β€œhttps://grinnode.live:3413”
More information on the free Grin API service here: GitHub - Grinnode-live/grinnode.live: High-Available GRIN API & GRIN Node
