Hi all
i have a problem, when i mine on my local stratum i note some out of sync problems.
My Grinnode are sometimes (every 5 - 10 min.) 1-3 Blocks behind/async to the Grinchain. See picture below
The Grin Explorer display the Block 51896
On my Grin node/stratum the Longest Chain is correct 51896, at the moment, but its happen that this also is 1-2 blocks behind the Grinchain.
But on my server.log my miner are working on block 51894… the switch happen few minutes later…
This is the reason for my rejected Shares…
How i can configure the sync “speed” of the stratum pool to the grin chain?
Can somebody help me?
I lose a lot oh time with mine shares they are older then 1 or 2 Blocks and this sucks… I try to install grin on my Ubuntu 16.04 Server, there i have the same problem. Now i run on Ubuntu 18.04
My last grin build is 30min ago. cargo build --release
Config grin-server.toml
i try:
archive_mode = true and false
chain_validation_mode = “EveryBlock” and Enabled
peers_preferred = [“35.226.50.239:3414”,“46.4.91.48:3414”,“199.247.30.118:3414”,“207.180.204.245:3414”,“47.4.91.48:3414”,“78.108.88.228:3414”,“88.201.129.205:3414”]
