Chain height not syncing
hey everyone, i am attempting to run a node on OSX. I’m held up at the moment, the chain height is stuck at 33390 (and 84% downloaded blocks). Connected to 23 peers at the moment. Any suggestions would be much appreciated
hay bigal I had the same problem with Linux cli node / wallet I deleted all folders in the chain_data folder and started grin node again and it seemed to fix the problem after it synchronized hope this helps with your problem.
after you re sync don’t forget to grin wallet restore as my grin wallet info showed 0 till I did.
thank you. you are wonderful. worked perfectly
:+1: gald to help…bigal
