1> [CMake] – Looking for memset_s
1> [CMake] – Looking for memset_s - not found
1> [CMake] CMake Error at C:\ProjekteGit\grin\grinplusplus\GrinPlusPlus\CMakeLists.txt:100 (find_package):
1> [CMake] Could not find a package configuration file provided by “unofficial-sodium”
1> [CMake] with any of the following names:
1> [CMake]
1> [CMake] unofficial-sodiumConfig.cmake
1> [CMake] unofficial-sodium-config.cmake
1> [CMake]
1> [CMake] Add the installation prefix of “unofficial-sodium” to CMAKE_PREFIX_PATH or
1> [CMake] set “unofficial-sodium_DIR” to a directory containing one of the above
1> [CMake] files. If “unofficial-sodium” provides a separate development package or
1> [CMake] SDK, be sure it has been installed.
1> [CMake]
1> [CMake]
1> [CMake] – Configuring incomplete, errors occurred!
Yes, there are plans in the making to fund implementing Parallel, Innitial Block Download (PIBD). Also support for biderectional payment proofs should be implemented and PayJoin. All in time.
Best to ask David in the Grin++ Telegram support channel
I took another look at the topic (building the Grin++ node).
I have described my installation process and troubleshooting here in case anyone else encounters similar problems.
