Hello,
I run on Linux - grin command and nothing happens
When I run grin wallet init - I get the following error:
Error instantiating wallet: LibWallet Error: Unknown Account Label ‘default’
Hello,
Try build it
I followed the instructions and when I build I get the following error:
— stderr
/usr/include/clang/6.0.0/include/emmintrin.h:2280:66: error: cannot convert between vector values of different size (’__v16hu’ (vector of 16 ‘unsigned short’ values) and ‘int’)
/usr/include/clang/6.0.0/include/emmintrin.h:2304:64: error: cannot convert between vector values of different size (’__v8su’ (vector of 8 ‘unsigned int’ values) and ‘int’)
/usr/include/clang/6.0.0/include/avx2intrin.h:151:66: error: cannot convert between vector values of different size (’__v32hu’ (vector of 32 ‘unsigned short’ values) and ‘int’)
/usr/include/clang/6.0.0/include/avx2intrin.h:161:66: error: cannot convert between vector values of different size (’__v16su’ (vector of 16 ‘unsigned int’ values) and ‘int’)
/usr/include/clang/6.0.0/include/fmaintrin.h:49:10: error: invalid conversion between vector type ‘__m128’ (vector of 4 ‘float’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/fmaintrin.h:55:10: error: invalid conversion between vector type ‘__m128d’ (vector of 2 ‘double’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/fmaintrin.h:73:10: error: invalid conversion between vector type ‘__m128’ (vector of 4 ‘float’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/fmaintrin.h:79:10: error: invalid conversion between vector type ‘__m128d’ (vector of 2 ‘double’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/fmaintrin.h:97:10: error: invalid conversion between vector type ‘__m128’ (vector of 4 ‘float’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/fmaintrin.h:103:10: error: invalid conversion between vector type ‘__m128d’ (vector of 2 ‘double’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/fmaintrin.h:121:10: error: invalid conversion between vector type ‘__m128’ (vector of 4 ‘float’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/fmaintrin.h:127:10: error: invalid conversion between vector type ‘__m128d’ (vector of 2 ‘double’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/avx512fintrin.h:1523:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/avx512fintrin.h:1545:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/avx512fintrin.h:5358:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/avx512fintrin.h:5379:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/avx512fintrin.h:5401:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/avx512fintrin.h:5422:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/usr/include/clang/6.0.0/include/avx512fintrin.h:5916:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
fatal error: too many errors emitted, stopping now [-ferror-limit=]
/usr/include/clang/6.0.0/include/emmintrin.h:2280:66: error: cannot convert between vector values of different size (’__v16hu’ (vector of 16 ‘unsigned short’ values) and ‘int’), err: true
/usr/include/clang/6.0.0/include/emmintrin.h:2304:64: error: cannot convert between vector values of different size (’__v8su’ (vector of 8 ‘unsigned int’ values) and ‘int’), err: true
/usr/include/clang/6.0.0/include/avx2intrin.h:151:66: error: cannot convert between vector values of different size (’__v32hu’ (vector of 32 ‘unsigned short’ values) and ‘int’), err: true
/usr/include/clang/6.0.0/include/avx2intrin.h:161:66: error: cannot convert between vector values of different size (’__v16su’ (vector of 16 ‘unsigned int’ values) and ‘int’), err: true
/usr/include/clang/6.0.0/include/fmaintrin.h:49:10: error: invalid conversion between vector type ‘__m128’ (vector of 4 ‘float’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/fmaintrin.h:55:10: error: invalid conversion between vector type ‘__m128d’ (vector of 2 ‘double’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/fmaintrin.h:73:10: error: invalid conversion between vector type ‘__m128’ (vector of 4 ‘float’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/fmaintrin.h:79:10: error: invalid conversion between vector type ‘__m128d’ (vector of 2 ‘double’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/fmaintrin.h:97:10: error: invalid conversion between vector type ‘__m128’ (vector of 4 ‘float’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/fmaintrin.h:103:10: error: invalid conversion between vector type ‘__m128d’ (vector of 2 ‘double’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/fmaintrin.h:121:10: error: invalid conversion between vector type ‘__m128’ (vector of 4 ‘float’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/fmaintrin.h:127:10: error: invalid conversion between vector type ‘__m128d’ (vector of 2 ‘double’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/avx512fintrin.h:1523:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/avx512fintrin.h:1545:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/avx512fintrin.h:5358:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/avx512fintrin.h:5379:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/avx512fintrin.h:5401:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/avx512fintrin.h:5422:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/usr/include/clang/6.0.0/include/avx512fintrin.h:5916:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
fatal error: too many errors emitted, stopping now [-ferror-limit=], err: true
thread ‘main’ panicked at ‘Unable to generate bindings: ()’, src/libcore/result.rs:1009:5
note: Run with RUST_BACKTRACE=1 for a backtrace.
warning: build failed, waiting for other jobs to finish…
error: build failed
I also run the following commands:
sudo apt-get install clang
sudo apt-get install ncurses
sudo apt-get install ncursesw5
sudo apt-get install libncurses5-dev libncursesw5-devnterna
sudo apt-get install libpng-dev --with-interna
sudo apt-get install zlib1g-dev --with-interna
make install
sudo apt-get update && sudo apt-get install pkg-config
sudo apt-get install libssl-dev
sudo apt-get install linux-headers-$(uname -r)
sudo apt-get update && sudo apt-get upgrade
wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | sudo apt-key add -
sudo apt-add-repository “deb https://apt.llvm.org/xenial/ llvm-toolchain-xenial-3.9 main”
sudo apt-get update
sudo apt-get install clang-3.9 lldb-3.9
I have clang 7.0.1
Debian 9
find / -name *clang*
