i build the code on my mac .follow this wiki: https://github.com/mimblewimble/grin/blob/master/doc/build.md.
But it failed .
Anyone can help me? thank you very much.
this is the log:
Compiling mortal v0.1.5
warning: missing documentation for macro
–> util/src/macros.rs:32:1
32 | macro_rules! impl_array_newtype {
note: lint level defined here
–> util/src/lib.rs:22:9
22 | #![warn(missing_docs)]
–> util/src/macros.rs:168:1
168 | macro_rules! impl_array_newtype_encodable {
–> util/src/macros.rs:222:1
222 | macro_rules! impl_array_newtype_show {
–> util/src/macros.rs:233:1
233 | macro_rules! impl_index_newtype {
Compiling grin_keychain v1.0.0 (/Users/haoshenyang/Downloads/grin-master/keychain)
Compiling linefeed v0.5.4
Compiling grin v1.0.0 (/Users/haoshenyang/Downloads/grin-master)
error: failed to run custom build command for croaring-sys v0.3.7
process didn’t exit successfully: /Users/haoshenyang/Downloads/grin-master/target/debug/build/croaring-sys-050b9986216158a2/build-script-build (exit code: 101)
— stdout
TARGET = Some(“x86_64-apple-darwin”)
OPT_LEVEL = Some(“0”)
HOST = Some(“x86_64-apple-darwin”)
CC_x86_64-apple-darwin = None
CC_x86_64_apple_darwin = None
HOST_CC = None
CC = None
CFLAGS_x86_64-apple-darwin = None
CFLAGS_x86_64_apple_darwin = None
HOST_CFLAGS = None
CFLAGS = None
DEBUG = Some(“true”)
running: “cc” “-O0” “-ffunction-sections” “-fdata-sections” “-fPIC” “-g” “-fno-omit-frame-pointer” “-m64” “-Wall” “-Wextra” “-std=c11” “-march=native” “-O3” “-o” “/Users/haoshenyang/Downloads/grin-master/target/debug/build/croaring-sys-acf285e72d93df79/out/CRoaring/roaring.o” “-c” “CRoaring/roaring.c”
exit code: 0
AR_x86_64-apple-darwin = None
AR_x86_64_apple_darwin = None
HOST_AR = None
AR = None
running: “ar” “crs” “/Users/haoshenyang/Downloads/grin-master/target/debug/build/croaring-sys-acf285e72d93df79/out/libroaring.a” “/Users/haoshenyang/Downloads/grin-master/target/debug/build/croaring-sys-acf285e72d93df79/out/CRoaring/roaring.o”
exit code: 0
cargo:rustc-link-lib=static=roaring
cargo:rustc-link-search=native=/Users/haoshenyang/Downloads/grin-master/target/debug/build/croaring-sys-acf285e72d93df79/out
— stderr
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/emmintrin.h:3427:10: error: returning ‘int’ from a function with incompatible result type ‘__m128’ (vector of 4 ‘float’ values)
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avxintrin.h:2228:10: error: invalid conversion between vector type ‘__m256’ (vector of 8 ‘float’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avxintrin.h:3115:10: error: invalid conversion between vector type ‘__m256d’ (vector of 4 ‘double’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avxintrin.h:3133:10: error: invalid conversion between vector type ‘__m256’ (vector of 8 ‘float’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:971:10: error: invalid conversion between vector type ‘__m512d’ (vector of 8 ‘double’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:982:10: error: invalid conversion between vector type ‘__m512d’ (vector of 8 ‘double’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:992:10: error: invalid conversion between vector type ‘__m512d’ (vector of 8 ‘double’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1021:10: error: invalid conversion between vector type ‘__m512’ (vector of 16 ‘float’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1032:10: error: invalid conversion between vector type ‘__m512’ (vector of 16 ‘float’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1042:10: error: invalid conversion between vector type ‘__m512’ (vector of 16 ‘float’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1126:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1136:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1144:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1154:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1164:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1172:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1182:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1192:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1200:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size
fatal error: too many errors emitted, stopping now [-ferror-limit=]
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/emmintrin.h:3427:10: error: returning ‘int’ from a function with incompatible result type ‘__m128’ (vector of 4 ‘float’ values), err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avxintrin.h:2228:10: error: invalid conversion between vector type ‘__m256’ (vector of 8 ‘float’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avxintrin.h:3115:10: error: invalid conversion between vector type ‘__m256d’ (vector of 4 ‘double’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avxintrin.h:3133:10: error: invalid conversion between vector type ‘__m256’ (vector of 8 ‘float’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:971:10: error: invalid conversion between vector type ‘__m512d’ (vector of 8 ‘double’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:982:10: error: invalid conversion between vector type ‘__m512d’ (vector of 8 ‘double’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:992:10: error: invalid conversion between vector type ‘__m512d’ (vector of 8 ‘double’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1021:10: error: invalid conversion between vector type ‘__m512’ (vector of 16 ‘float’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1032:10: error: invalid conversion between vector type ‘__m512’ (vector of 16 ‘float’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1042:10: error: invalid conversion between vector type ‘__m512’ (vector of 16 ‘float’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1126:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1136:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1144:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1154:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1164:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1172:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1182:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1192:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/lib/clang/10.0.0/include/avx512fintrin.h:1200:10: error: invalid conversion between vector type ‘__m512i’ (vector of 8 ‘long long’ values) and integer type ‘int’ of different size, err: true
fatal error: too many errors emitted, stopping now [-ferror-limit=], err: true
thread ‘main’ panicked at ‘Unable to generate bindings: ()’, src/libcore/result.rs:997:5
note: Run with RUST_BACKTRACE=1 environment variable to display a backtrace.
