I would be extermely surprised if there is a single standard exchange at launch, having a non “script” and non “erc20” means rewritting protocols up to the new standards and to work with existing systems… Soooo no
Any exchange will be new and unknown and clunky and temporary.
I would rather short this market (at first) than buy into it, because the tight initial supply will put prices at a premium
Manual and or clunky exchanges will put the same pressure on demand
The market will be insane and illiqiud nothing as simple as “merely overpriced”
Any estimate for number of miners, which at the moment might be expected to be around 10% of existing GPUs (Set mainnet initial difficulty · Issue #2121 · mimblewimble/grin · GitHub), doesn’t and simply cannot take into account how much additional or new GPU capacity is being brought online in anticipation for the mainnet launch.
Can you please confirm that QB .com will support Grin trading or can we consider that this exchange will not be involved ? (because I also don’t find any information about this). It would be good to clarify. Thanks
I have guessed so however the supply on Bisq is scarce (to avoid saying non-existent yet). I will wait for supplies on Bisq to make my experience using the coin… thx
Popularity isn’t a replacement for a market maker. If we go full organic the launch price will be all over the place for weeks making it not a fun place to trade in.
It’s possible the gpu renting systems will work as replacement and this market is as healthy as they get in oh 2 weeks ish rather then 3 month ish(or the market makers are being quiet)
The engine is unquestionably full, but is there spark plugs?
it does have beam up already, so I believe the “at launch” claims, it may actually be a few days but so be it.
ui is better then I expected
actual privacy rambling
cons:
it currently has 26 btc/usd traders, and a grand total of .02 btc on the buying side of beam/btc; liquidity is super low, I expect that to continue, its important it exists but for any kind of trading that is more often then once a year I think its out of the question, your be paying percents on arbitration and other related shit
… does it store my key locally… on a desktop… ewwwww no no no no, I’m never putting btc on a desktop os without something extra, I have a qubes setup; but thats not something I want to boot into daily to make trades and not something I would suggest to normies. If it was just grin maybe if I forced myself to setup cold storage a year from now before the viruses that look for its wallet data, but thats a high risk from where I’m sitting
I don’t believe this will ever be a healthy enough market for me to play with, without an alternative motive like arbitrage, or enabling laundering
I’ll probably be signing up regardless of what anyone says, but has someone been thru the process and some light due diligence on qb yet?
