Hi! I have a problem. Some grin dissapeared from my wallet.
I can see them with status “Locked by previous transaction” when i do “grin wallet info”.
When i do “grin wallet txs”, i don’t see any outgoing successfull txs (and past 5 my outgoing txs are cancelled)
When i do “grin wallet outputs”, i see that first 4 of my incoming txs have status “locked” (sum of them is locked) and past two have status “unspent”.
This may be an error with your .api_secret file (used by the grin node to authenticate clients). It should be found inside your ~/.grin/main directory (or whatever directory is used by your grin node and wallet).
