Added support for Grin CuckarooM-29 (hard fork on Jan 16th) on 8G AMD GPUs, use --coin GRIN-C29M to mine with it.
Hint: The miner will pause until the fork height is reached not to waste energy. Use --coin FLOO-C29M to test the miner in floonet testnet before if you like.
Improved C31 performance on 8G cards by ~5% (Windows: relatively to 0.9.3, Linux: relatively to 0.9.4)
Navi on Windows now runs same kernels as in Linux
Slightly lowered energy use of C31 / C32 solver
Added aliases GRIN-C31 and GRIN-C32 for the Cuckatoo solvers (the old names still exist and continue to work)
Driver requirement for all GRIN codes: 18.50 for all pre-Navi cards, 19.30 for Navi (Linux); Adrenaline 18.12 for all pre-Navi, Adrenaline 19.10 for Navi
It should be rather simple.
When you unpacked the miner there are .sh files, one for example named mine_grin_29.sh
In there you just need to replace your pool address and port (line 7) and your wallet / account at that pool (line 8) and on some pools your worker password (line 9). Thats it. Afterwards run the modified .sh file from command line.
There is also an .sh file for C31, for C32 I forgot it, but its changing one number in the C31 file
I am running some NVidia 1080tis and the fidelity is at 1.01 on both 14 and 42 cycles, so no issues there. Further, I am getting a 7% better hashrate per GPU than I was getting with Gminer v1.96, so definitely no complaints.
