GRIN requires a username to mine in [F2Pool]. Therefore an f2pool account is required. If you don’t have one, please register on F2Pool.
Download mining software,there are several high performance software for Grin.
[Miner Master] (Support N-card mining)
[Bminer official] (Support N-card mining)
[Miner OS](Support N-card and A-card mining)
[Miner Babe] (Support N-card and A-card mining)
[GRIN official] (Support N-card and A-card mining) (Hashrate is quite low, difficult to use, not recommended) -
Set parameters,take Bminer as a sample:
Download the Bminer mining software and unzip the files. Right click on “start.bat” and click “Edit”.
Set the parameters as follows:
bminer -uri cuckaroo29://username.workername:foo@grin29.f2pool.com:13654
Save the “start.bat” file and then double-click to start mining.
- To view the operational status and daily income of the mining machine, you can access the https://www.f2pool.com website, click on the search bar in the upper right corner, and enter the wallet address to check.
more information:https://blog.f2pool.com/en/mining-tutorial-en/grin_en
