This release is mostly focused on improving the synchronization process. Thank you to those loyal community members who help testing and reporting issues, you know who you are. Thank you.
- Added ability to pass config file path on starting node.
- Added preferred peers, blocked peers and allowed peers feature.
- Reduced buffer size due to slow peers.
- Improved sockets handling.
- Fixed issues connecting to peers.
- Fixed node crashes.
- Fixed Segmentation Fault on peers manager.
- Fixed Transport endpoint is not connected on Seeder.
- Fixed problems pruning inactive peers.
- Fixed problems with empty config.
- Fixed problems updating peers configuration through the API.
- Fixed connections numbers calculation.
- Fixed socket connection instability while synching.
- Fixed issues terminating Tor process.
- Fixed issues downloading state.
