Are you feeling any better?
Not really, but I keep working on it if I am able to.
Update for weeks 22/06 to 06/07:
- These weeks I worked further on the Ledger firmware. I concentrated on reusing parts of the Beam firmware.
- I started implementing tests in C and Python.
- The memory space of the Ledger device is rather limited. So I would first implement the firmware without the Grin version of PSBTs.
Update for weeks 06/07 to 20/07:
I worked further on the Ledger firmware. I worked on the user interface code. I implemented the tests further.
I looked into detail on the BIP standards as they are used in Grin and Ledger, surrounding the topic of key derivation.
Lots of small things in the firmware, a lot of debugging.
Update for weeks 20/07 to 03/08:
I looked these weeks into the Bulletproof paper and code, to understand the elements I need. It’s the generation side I need to focus on, verification can happen on desktop.
I worked further on the Grin++ code, removing compilation errors. And a lot of reading code.
Update for weeks 03/08 to 17/08:
On the firmware side, I worked further on the test for signing, which included some utilities, like using the RNG from Ledger, printing a hex number etc. I made a handler instruction for running the tests.
On the grin-wallet and grin++ side, I worked further on PSGT, for some alternation.
I started writing some documentation, such as the required third-party article as described here, by Ledger: Documentation requirements | Developers
Next, I will design the 2 mandatory icons, as described here: Design requirements | Developers
Then, I will work further on the firmware tests.
Update for weeks August 17 to August 31:
- Further work on implementing tests, work on Grin’s version of PSBT in grin-wallet
- Implemented signing of payment proof with ed25517 curve, using the Ledger SDK. I got to know the Ledger SDK better (e.g. nanos-secure-sdk/lcx_ecschnorr.h at 5e3e0595cf364cc784b247961879c707f495697b · LedgerHQ/nanos-secure-sdk · GitHub). I am using this for Schnorr signatures.
- I am only considering the non multi-signature case for now.
That curve is new to me:-)
I’m sorry, I meant Ed25519 of course.
How is this going @markhollis? Is there anything that someone could help you with? I am a developer with little crypto experience but would help with something if I can. I have a ledger I could use.
Hi Cryptised, thanks. It goes better than a while ago, I made some good progress.
At some point, I will need user testing the app.
I’m going to think about how I could assign something more developer oriented, but it’s hard at the moment to divide this now in well rounded tasks.
Update for weeks August 31 to September 14:
- Further work on Grin’s PSBT version in grin-wallet.
- Implementation of key derivation in the Ledger app.
- Implementation of kernel offset.
Next is considering the finalize part more.
Implementing the rangeproof part is challenging. Here are some notes about the use of rangeproofs in grin-wallet. It can contain faults or inconsistencies and it is certainly incomplete.
Related work
There is some previous work done on rangeproofs in Monero
There is a publication on a Monero Trezor implementation
See:
- https://eprint.iacr.org/2020/281.pdf
- GitHub - ph4r05/monero-tx-paper: Repository related to the paper "Privacy-friendly Monero transaction signing on a hardware wallet"
Monero has switched to BP++.
There is also the Beam HW wallet implementation.
I haven’t studied these implementation in depth yet.
If someone knows related work regarding implementations of Bulletproofs on Ledger/Trezor, let me know.
In the following, I will give some comments on the rangeproof code, as it is used in Grin.
Rangeproof
Rangeproof signing is calculated by the HW. Note that Rangeproof validation will happen by the host.
“A rangeproof is therefore attached to every output and proves that its value isn’t negative and that its size is restricted so it doesn’t overflow”. Mimblewimble - Grin Documentation Rangeproof creating is done in the receiver action.
The Rangeproof field in the struct Output is here defined: grin/core/src/core/transaction.rs at f51b6e13761ac4c3c8e57904618ef431c14c6227 · mimblewimble/grin · GitHub
(Here the proof is verified. pub fn verify_proof(&self) → Result<(), Error>: grin/core/src/core/transaction.rs at f51b6e13761ac4c3c8e57904618ef431c14c6227 · mimblewimble/grin · GitHub )
The build::output() method fn output<K, B>(value: u64, key_id: Identifier) is defined here. It calls the proof::create function. grin/core/src/libtx/build.rs at 1b8acee72e7a4236cdf8561a7af5f894bfe11985 · mimblewimble/grin · GitHub
This creates the rangeproof/bulletproof itself: grin/core/src/libtx/proof.rs at 1b8acee72e7a4236cdf8561a7af5f894bfe11985 · mimblewimble/grin · GitHub
An output with a given rangeproof (created in the previous method) is created here: grin/core/src/core/transaction.rs at f51b6e13761ac4c3c8e57904618ef431c14c6227 · mimblewimble/grin · GitHub This method is used in the output function above: tx.with_output(Output::new(OutputFeatures::Plain, commit, proof)),
The previous is then used in the receive action., using tx::add_output_to_slate() (grin-wallet/libwallet/src/internal/tx.rs at 8547f4a162b466a1dacef63df2282b34c3964e78 · mimblewimble/grin-wallet · GitHub), which then calls build::output grin/core/src/libtx/build.rs at f51b6e13761ac4c3c8e57904618ef431c14c6227 · mimblewimble/grin · GitHub
Other interesting parts in the Wallet layer:
- test_rewind_range_proof(): grin-wallet/libwallet/tests/libwallet.rs at bdc5bd748a4e399e6febc5e3c4974e569ee39638 · mimblewimble/grin-wallet · GitHub
Now for the bulletproof algorithm itself:
It derives a secret key, using the secp256k1 curve. (grin/core/src/libtx/proof.rs at 1b8acee72e7a4236cdf8561a7af5f894bfe11985 · mimblewimble/grin · GitHub) This should happen on the HW.
Private nonce is created using this method: grin/core/src/libtx/proof.rs at 1b8acee72e7a4236cdf8561a7af5f894bfe11985 · mimblewimble/grin · GitHub Likely this must happen on the HW (I’m not sure).
It then call the secp.bullet_proof(), using the FFI and the secp256k1 library. GitHub - mimblewimble/rust-secp256k1-zkp: ZKP fork for rust-secp256k1, adds wrappers for range proofs, pedersen commitments, etc
pub fn range_proof() rust-secp256k1-zkp/src/pedersen.rs at 4128f64505143859c48fab04158c25127a2a9858 · mimblewimble/rust-secp256k1-zkp · GitHub
ffi::secp256k1_rangeproof_sign() called: rust-secp256k1-zkp/src/pedersen.rs at 4128f64505143859c48fab04158c25127a2a9858 · mimblewimble/rust-secp256k1-zkp · GitHub
int secp256k1_rangeproof_sign() (secp256k1-zkp/src/modules/rangeproof/main_impl.h at 8d1f5bb152580446a3438cd705caebacc2a5d850 · mimblewimble/secp256k1-zkp · GitHub) acts mainly as a checker for the arguments, to call secp256k1_rangeproof_prove(). blind is here the secret key. The normal case, with tau_x, t_one, t_two and commits equal to NULL, seems to be the simplest case.
secp256k1_rangeproof_prove() is here: secp256k1-zkp/src/modules/bulletproofs/main_impl.h at 8d1f5bb152580446a3438cd705caebacc2a5d850 · mimblewimble/secp256k1-zkp · GitHub
Beginning, lots of checks that the arguments are correct
Commitment is calculated from Blindingfactor, must happen on the device I think.
Main functions called seem to be these two:
- secp256k1_pedersen_commitment_load: secp256k1-zkp/src/modules/bulletproofs/main_impl.h at 8d1f5bb152580446a3438cd705caebacc2a5d850 · mimblewimble/secp256k1-zkp · GitHub But this is in the multi party case.
- secp256k1_bulletproof_rangeproof_prove_impl call: secp256k1-zkp/src/modules/bulletproofs/main_impl.h at 8d1f5bb152580446a3438cd705caebacc2a5d850 · mimblewimble/secp256k1-zkp · GitHub
Parameters: blind: 32-byte blinding factor used by commit. nonce: 32-byte secret nonce used to initialize the proof (value can be reverse-engineered out of the proof if this secret is known.)
This is part of the BP normal case. Code in this block should be done on the HW, as it uses the blinding factor. secp256k1-zkp/src/modules/bulletproofs/main_impl.h at 8d1f5bb152580446a3438cd705caebacc2a5d850 · mimblewimble/secp256k1-zkp · GitHub This requires EC multiplication, for which I’ve seen example code, not using secp256k1, but the Ledger SDK.
secp256k1_bulletproof_rangeproof_prove_impl implementation: secp256k1-zkp/src/modules/bulletproofs/rangeproof_impl.h at 8d1f5bb152580446a3438cd705caebacc2a5d850 · mimblewimble/secp256k1-zkp · GitHub
This secp256k1_lr_generator_init methods needs to be done on the HW, as it uses the secret nonce: secp256k1-zkp/src/modules/bulletproofs/rangeproof_impl.h at 8d1f5bb152580446a3438cd705caebacc2a5d850 · mimblewimble/secp256k1-zkp · GitHub
I don’t understand the usage of gen and blinding gen at the moment
This needs to be done on the HW, uses blind: secp256k1-zkp/src/modules/bulletproofs/rangeproof_impl.h at 8d1f5bb152580446a3438cd705caebacc2a5d850 · mimblewimble/secp256k1-zkp · GitHub
This method (inner product proof secp256k1_bulletproof_inner_product_prove_impl) doesn’t use nonce or blind, so it doesn’t need in principle the HW?: secp256k1-zkp/src/modules/bulletproofs/rangeproof_impl.h at 8d1f5bb152580446a3438cd705caebacc2a5d850 · mimblewimble/secp256k1-zkp · GitHub
This note is certainly incomplete, especially the analysis of the Bulletproof algorithm itself.
The question I have is how to offload the part which uses the secret nonce and blinding factor to the HW. Perhaps studying related work will help here. If there are suggestions, they are very welcome.
If you wish, you could work in collaboration with Nicolas Flamel. He made some good advancement on his own MWC ledger integration.
Update for weeks September 14 to September 28:
I worked these weeks on:
- Adjust offset
- Further work on signing of payment proof with ed25519 key (Dalek key in grin-wallet) and sending the information needed for this.
- Work on grin-wallet. It seems best to implement a method for each action in grin-wallet that must be delegated to the HW (e.g. fn adjust_offset, fn create_payment_proof).
Now working on including inputs and outputs.
Update for weeks September 28 to October 12:
- including inputs and outputs on the HW side
- commiting to a value on the HW side
- Lots of debugging. I decided to go for a Rust HW app, instead of a C app. It offers security review benefits and it is also easier to program in. grin-wallet is also written in Rust, so that would simplify translations. I already translated a big part of my app into Rust.
Thanks for your work Mark. I’ll be ecstatic to see this complete.
Can I ask whether the work you’ve done so far will require custom firmware on the Ledger or would it be possible that Ledger could integrate it (if they wanted)?
It would be an app that can be installed on the Ledger, just like e.g. the Bitcoin and Monero apps can be installed.
It doesn’t need extra firmware.
I don’t see limitations at the moment why Ledger could not integrate it.
Really appreciate your work man!
I also have a question: When we install the app on the Ledger device, are we gonna use Grin++ or Ledger Live for transactions?
Thanks!
Hi andro,
Thanks for your question. Initially, grin-wallet will be used. Then I will look for Ledger Live (this is required for the bounty). Grin++ would be nice as well, given the experience from supporting it in grin-wallet.
