Grin Global Map
Claude code is helping me to build this map Grin Node World Map — Global Grin Network Peer Map
i’m quite surprised that Grin++ is still too popular, since other grin maps are no longer available so i don’t have reference, if someone is running grin++, can check if your ip is listed?
and about the stats page, the graph is slightly different than 2miner stats, i crossed check with several AI and they said it’s correct, will need dev experts to review. The full source code is public at GitHub - noobvie/Grin-Node-Toolkit · GitHub
The following data seems wrong:
i tested several grin++ and it could show my ips and grin++ correctly. However, i’m quite surprised many people are still using grin++, that may explain why sometimes we had people raised the issue in grin++ than other wallets
there is not full list of peers, I guess a problem can be sync of node.
must be ~20k
685 Grin++ peers
i only keep data of 7 days, how long you get for having 685 grin++ data ?
for months, at freshly launched node I got 1751 peers, for example, I see your node is missing IPs of peers from Seeds and Seed list itself. Also there are 0 Grin++ peers from seeds. Seems like known problem with Grin++ banning Rust node peers, like you are running separate network.
UPD:
more peers came after some minutes of sync, still 0 Grin++ nodes :thinking:
I thought that’s a number of the connected peers, otherwise it makes sense.
A little update, I’ve added Ipv6 and 2 more agent names ‘MW/Grim’ and “G++ Weische” on world map page
I also found grin/p2p/src/types.rs at master · mimblewimble/grin · GitHub , which means it supports ipv6? ( use std::net::{IpAddr, Ipv4Addr, Ipv6Addr, SocketAddr, SocketAddrV4, SocketAddrV6, ToSocketAddrs}; ) I tested to change the grin-server.toml file from host = “0.0.0.0” to host = “::”. Still testing how it will be in ipv6, not sure if anyone tested before.
Finally, first ipv6 appeared in global peer map :world_map:
CIA running a couple nodes just west of Washington DC :smiley:
The Central Intelligence Agency (CIA) maintains a significant operational presence in Reston, Virginia, housing key facilities such as the CIA Center for Open Source Intelligence and the Sherman Kent School for Intelligence Analysis.
In fact, they’re controlling everywhere https://www.youtube.com/watch?v=-KgX9xyIRK8
If the CIA is grinning, that means we are winning. Even they can smell the potential of grin.
That is a mighty good looking map Sir.
