Hello everyone,
To make development progress easier to follow and keep all updates in one place, this thread will serve as a central log for monthly development reports. Each month, contributors involved in the project can post a summary of completed work.
Monthly updates will be added as replies to this thread.
Summary - May 2026
A brief overview of the pull requests I reviewed, created, and contributed to in the following repositories:
mimblewimble/grin-wallet
mimblewimble/grin
Reviewed & Merged
#748 - Save last scanned block info for wallet scanning
mimblewimble/grin
Reviewed & Merged
#3836 - tui: show server initialization status and error
#3825 - Migrate from lmdb-zero to heed
#3843 - Change default IP address for P2PConfig to IPv6
#3834 - Update Rust edition to 2021
Created & Merged
#3846 - Add DNS Seeder fountainoffairfortune
#3844 - Snap addition
#3840 - Clarify the blinding factor range proof explanation and include remaining typo fixes
#3839 - Telegram GGC channel
#3833 - docs: update contributing process
#3832 - ci: staging docker build
#3831 - Test staging PR permissions
#3829 - Include git information in Docker builds and display git reference in version output
Created
#3847 - Add Telegram notifications for GitHub workflows
#3835 - Improve PIHD sync and PIBD segment handling
Additional Topics
Built a Docker-based test farm using Docker, Grafana, and Grin++/Grinffindor for testing and monitoring
Agenda - June 2026
grin-wallet (Review)
#750 - Replace tor process with arti client
grin
grin++
General
Review and work through open issues
Continue testing, reviewing, and maintaining the Grin ecosystem
Summary - May - early June 2026
mimblewimble/grin
Updated
Created
Tested
#754 - Update contracts to current staging
mimblewimble/grin
Updated
Created
#3829 - Include git info into docker build, show git ref at version
#3851 - Do not use workspace for submodules
Tested & Reviewed
#3820 - Optimize PMMR segments to only include hashes at pruning boundaries
#3849 - propagate lmdb iterator page errors
#3850 - PIBD: bound segment decoding allocations
Additional Topics
Grim: ci macos runner, update grin submodules, tx repost fix, some UI fixes.
Impressive work @wiesche and @ardocrat ! Keep it up !
Summary - June 2026
mimblewimble/grin
Reviewed & Merged
#750 - Integrated Tor arti Client
#755 - Update lmdb
#758 - Node submodules
#762 - Global Tor client state
#763 - Optimize tor sync flow
Reviewed
#754 - Update contracts to current staging + fix #729
mimblewimble/grin
Reviewed & Merged
#3823 - PIBD peers fix
#3860 - LMDB resize fixes
#3868 - Fix TUI server startup shutdown handling
Created & Merged
#3861 - Validate bitmap segment indices on decode
#3862 - Improve seedcheck diagnostics and Windows cleanup
#3863 - add dns seeder
#3866 - Fix pool fuzz build
#3875 - Harden PIBD segment retry and recovery
#3877 - Improve macOS TUI support with crossterm backend
#3878 - Notify Telegram on merged pull requests
#3879 - add PIHD header segment protocol
#3880 - avoid panic on invalid config migration
Created
#3881 - Create API secrets at configured paths
#3882 - Implement PIHD header sync
Reviewed
General
Continue PIHD/PIBD implementation and testing
Summary - June - early July 2026
mimblewimble/grin
Updated
Created
#765 - Connection timeout
#768 - Update deps
#769 - Global config instance
Tested
mimblewimble/grin
Updated
Created
#3864 - Allow running multiple nodes from single IP
#3865 - Optimize LMDB migration size check
#3883 - Update API dependencies
#3884 - Fuzz build fix
#3885 - Fix tests using rustls
Tested & Reviewed
#3863 - Add dns seeder
#3879 - Add PIHD header segment protocol
#3880 - Avoid panic on invalid config migration
#3904 - docs: accurate input/output linking in grin4bitcoiners.md
#3905 - Migrate TUI from cursive to ratatui
Additional Topics
Grim: optimize Tor, ipv6 setup for APIs, encrypt Slatepack for invoice with address, finalize over Tor, fix i18n for Chinese.
Summary - July 2026
mimblewimble/grin
mimblewimble/mwixnet
Reviewed & Merged
#768 - Update deps
#773 - Wrong Slatepack address fix
#779 - Use native TLS for client
Created & Merged
#774 - Bump lodash from 4.17.21 to 4.18.1
#781 - Expose Mwixnet onion APIs for external consumers
Created
#777 - Update jayson and uuid
#778 - RFC: Explore running a node and wallet in the same process
#783 - Mwixnet wallet support
Reviewed
#771 - Add interactive TUI mode for grin-wallet
#772 - Revive node and wallet multi-process integration suite
#780 - Optimize outputs scan and selection
mimblewimble/grin
Reviewed & Merged
#3864 - Compare peer ports to allow multiple nodes from a single IP
#3886 - Add unit tests for the stratum server module
#3911 - Use Tokio channel for REST shutdown signal
#3912 - Install rustls provider at a single place
#3914 - Keep preferred peers when enough outbound peers are connected
#3917 - REST address bind fix
#3920 - Better initialization of global variables
Created & Merged
#3913 - Show node runtime in status view
Reviewed
#3876 - Refactor stratum server leak handling
#3887 - Rewrite pool documentation for the current txpool/stempool design
#3888 - Clean old txhashset snapshot archives
#3889 - Stop stratum TCP connection leaks under reconnect load
#3890 - Keep Node API responsive during txhashset creation
#3891 - Claim state sync requests with compare_exchange
#3892 - Throttle chain compaction with a wall-clock interval
#3893 - Fall back to defaults for missing configuration keys
#3894 - Improve readiness reporting while the node is syncing
#3895 - Abort chain compaction cleanly on shutdown
#3896 - Handle clock skew with FutureTimeLimit
#3897 - Expose stratum mining statistics through the Owner API
#3898 - Update peer difficulty on header and block receipt
#3899 - Cache packed proof nonces for cheaper header and block hashing
#3900 - Rebroadcast transactions recovered from the reorg cache
#3901 - Prune dead stratum workers
#3902 - Bound MerkleProof path length during deserialization
#3903 - Wait for P2P send-buffer space on request responses
#3905 - Migrate the TUI from cursive to ratatui
#3906 - Speed up chain compaction and harden PIBD validation
#3907 - Add optional TLS for P2P connections
#3908 - Gracefully handle out-of-disk-space failures
Created
#34 - Restore compatibility with Grin staging
General
Completed and merged the PIHD header synchronization implementation
Started integrating Mwixnet support into grin-wallet
Reviewed performance, storage, recovery, TUI, and API changes
Continued reviewing and working through open issues
Summary - July - early August 2026
mimblewimble/grin
Updated
#768 - Update dependencies
#769 - Global configuration instance
Created
#782 - Make updater apis public
#784 - Release 5.5.0
#785 - Fix Github CI MacOS build
Reviewed
mimblewimbe/grin
Created
#3919 - Fix peers monitor log message and prevent underflow
#3922 - Get read limit from reader
#3924 - Release 5.5.1
Tested & Reviewed
#3915 - Make the sparse PIBD segment optimization safe to apply
Reviewed
General
Updated commons dependencies to fix possible vulnerabilities
Fixed an issue to send big amount from grin-wallet optimizing outputs sync speed
Created stable release for Grim GUI adding last changes from staging branches
Prepared release 5.5.0 for wallet and 5.5.1 for node
Started multisig reviewing AI suggestion as example
Took vacation till 1st September.
wiesche
September 1, 2026, 10:09am
9
Summary - August 2026
A brief overview of the pull requests I reviewed, created, and continued working on in the following repositories:
mimblewimble/grin
meilisearch/lmdb
Reviewed & Merged
#782 - Make updater APIs public
Created & Merged
Created
#787 - Centralize Grin workspace dependencies
#793 - Support kernel features when creating slates
#795 - Fix transaction filter
#797 - Handle unavailable terminal colors
#798 - Reject invalid invoice locking
#799 - Reject zero send amounts
#800 - Clarify BIP32 derivation paths
#801 - Avoid empty wallet seeds
#802 - Add confirmed transaction height
#804 - Use current header version in new slates
#805 - Unpack plain Slatepacks without password
#806 - Add multi-OS builds
#807 - Reject invoice slates in receive
#808 - Display Slatepack addresses
Continued Development
mimblewimble/grin
Reviewed & Merged
Created
#3928 - Add multi-OS builds
#3932 - Fix PIBD resume stall with newer archive target
#3934 - Refresh PIBD test fixtures
meilisearch/lmdb
Created
#5 - Fix stale mappings on OpenBSD
General
Added portable Linux musl, FreeBSD, and OpenBSD build and release workflows for Grin and grin-wallet
Setup VMs for building, testing, and running the new platform binaries
synchronization tests on NixOS, FreeBSD, and OpenBSD
Investigated OpenBSD LMDB mapping consistency and performance problems
BOBO
September 1, 2026, 3:28pm
10
Thank you.
It is precisely because of your continuous research and development that Grin has never died. Earlier today, I was chatting with a friend on WeChat voice about the bleak state of altcoinsâBeam being delisted from Gate.io , and Grinâs price keep falling. just because I often come to this forum,I know that some people like CobragrinăwiescheăwaynegeorgeăAnynomous ătrabăardocratăsyntaxjakăbrugesăNeo-Geoăgig and many other people silence in the forum, I think if there are some people here to contribute for this project, that it is still a good choice to mine or buy the grin coin.
At the the time,I also want to thank every reader who comes to this forumâyour very presence is part of the Grin ecosystem. What keeps a project alive is not just code updates, but the fact that there are still people connected to each other, watching Grin move forward together.
Summary - Half of September 2026
mimblewimble/grin
Created
#810 - Downgrade arti Tor lib
#814 - Lock outputs before sending with Tor
#815 - Accounts balances
#816 - Send between accounts
#819 - Wallet initialization error message
#821 - Slatepack address index on send
#822 - Compact transaction table at CLI view
#823 - Add linter to CI
Reviewed
#787 - Centralize workspaces dependencies
#793 - Support kernel features on slates creation
#800 - Clarify BIP32 paths
#805 - Unpack plain slatepacks without password
#807 - Reject wrong slates on receive and finalize
#808 - Display slatepack address
#820 - Show HTTP status on node request fail
mimblewimble/grin
Created
#3935 - Make tx-related constants public
#3937 - Merge master to staging
#3944 - Add linter to CI
Reviewed
#3932 - Fix PIBD resume stall with newer archive target- #3932
General
Fixed some issues at GUI
Started mwixnet testing
Summary - September 2026
A brief overview of the pull requests I reviewed, created, contributed to, and continued working on in the following repositories:
mimblewimble/grin
Reviewed & Merged
#810 - Downgrade Arti to 0.43
#815 - Account balances
Created & Merged
#820 - Show HTTP status when node requests fail
Previously Created & Merged This Month
#807 - Reject wrong slate states in receive and finalize
Reviewed
#822 - Compact transaction table in the CLI
Continued Development & Contributions
#754 - Update contracts to current staging, improve payment proofs and add tests
#793 - Support kernel features when creating slates, including NRD compatibility fixes
#802 - Add confirmed transaction height and handle reorgs
#818 - Send between accounts, including transaction storage and cancellation fixes
#819 - Improve wallet initialization checks and errors
mimblewimble/grin
Reviewed & Merged
#3935 - Make transaction-related constants public
Continued Development & Merged
#3932 - Fix PIBD resume stalls with newer archive targets, including pruned subtree overlap handling
Created
#3939 - Fix archive compaction performance and speed up missing output index repairs
