Hi,
As per title, how can I get some test coins on Floonet?
Hi,
curl http://gringod.info
@kargakis It reports:
## Grintings stranger, we can't send grin to you now. ##
## Your wallet is inaccessible @ 13415 from outside ##
1. Check your router forwards port 13415 to this PC
2. Check that you have wallet listening on 0.0.0.0:13415
Or on your public IP 108.61.217.107:13415
3. Make sure you are running both GRIN node and wallet listener (grin wallet listen)
So I want to grin-wallet listen to port 13415, but it still listen the default port 3415.
> grin-wallet -e listen --port 13415
Password:
20190413 16:23:36.373 WARN grin_wallet_controller::controller - Starting HTTP Foreign listener API server at 0.0.0.0:3415.
20190413 16:23:36.374 WARN grin_wallet_controller::controller - HTTP Foreign listener started.
I find in file ~/.grin/floo/grin-server.toml, there’s a line showing that port 13415 is used to receive mining reward.
#the wallet receiver to which coinbase rewards will be sent
wallet_listener_url = "http://127.0.0.1:13415"
@jasonzhouu you are trying to receive floonet coins with a mainnet listener.
Try grin --floonet wallet listen
error: Found argument 'wallet' which wasn't expected, or isn't valid in this context
USAGE:
grin --floonet
PS. the version of grin used is 1.1.0-beta.1
I can reproduce in 1.1.0-beta.1, thanks for reporting it! I opened https://github.com/mimblewimble/grin-wallet/issues/39
In the meantime, if you want to finish that floonet payment, 1.0.3 works fine.
Sorry, forgot about the binaries split,
grin-wallet --floonet listen
works fine for me in v1.1.0-beta1
@kargakis Sucessfully listen on port 13415, but failed to connect to gringod.info.
> grin-wallet --floonet -e listen
Password:
20190414 11:05:21.762 WARN grin_wallet_controller::controller - Starting HTTP Foreign listener API server at 0.0.0.0:13415.
20190414 11:05:21.763 WARN grin_wallet_controller::controller - HTTP Foreign listener started.
curl: (7) Failed to connect to gringod.info port 80: Connection refused
Unfortunate, this is an issue with gringod
Yes, wish another guy can create a testcoin faucet.
@xiaojay says he will send me some testcoins.
hello,i want to test wallet api,so i need some floonet coin, who can help me? my wallet713 address is xd7CDssUQfEh59ZUfES7t5jygQd3uH2Vx5KxDpS7oeocvyKx7vGR
