Dear Community Council - Where Can I Contribute?
Hi, I’d like to dedicate time to writing code for Grin-related software. I’m very much a beginner so this might end up being fruitless but are there any areas around Grin that could use my assistance? Specifically ones that will lead to me getting paid. Thank you
Thank you for participating in grin Coins, and we work together,MGGA(make grin great again)
I don’t know how to code, so I’ll mine to support the grin network.
In addition, I feel that I participate in GRIN forums and online discussions as a way to help the development of the grin Coins.
let us promote and help the grin.
感谢你参与古灵币,我们一起努力
我就不会代代码,所以我就挖矿支持古灵网络,另外,我觉得自己多参与论坛,网络讨论和宣传古灵币,也是一种帮助古灵币的发展。
https://grinpost.substack.com/p/spring-time
Here you can find open issues
You could connect with @Anynomous who is also (sort of) a beginner and contributing. First recommendation is to join the keybase chat though. For better or worse, that is where development discussion mostly is.
If you are a beginning programmer, making contributions that are paid will be challanging.
It also really depends on what programming languages you know. If you want to just work with Grin you can use the API or mimblewimble.py.
If you know some Rust you can can look at github issues and start fixing those.
For inspiration see tools:
→ GitHub - grincc/hub: GRIN scripts and tools
For Developers:
