when connecting msi z270a pro no internet connection! when you connect another motherboard there, what are these things? only the motherboard is changed, minerbabe OS
I don’t think that this is the proper place to ask about your motherboard that does not work. Have you tried the motherboard manufacturer’s support ? Does that motherboard work under Windows? If yes, perhaps minerbabe OS does not support the ethernet port on that motherboard. Again, minerbabe OS would be a better place to ask.
I wanted help, well, everything is clear in general! accordingly, she worked on the hive os, minerbabe has no forum and technical support, and there is not any help in the telegram
Show ifconfig, iwconfig on your system and do you connected motherboard with network card? All drivers are up to date?
