Coin withdrawals using ngrok.io from Chinese exchanges like BitForex
Hey there,
I wanted to trade a few GRIN to play around, but the only trustworthy exchange I could find to trade was BitForex.
However, they support only withdrawals via https connection. File transfer is not supported.
I tried using https://ngrok.io but it didn’t work so far. I tried both the official GRIN wallet and GrinPlusPlus (GRIN++). It looks like they fail to connect at all, when the transaction is cancelled, the logs show nothing.
Has anyone ever managed to withdraw GRIN from BitForex or similar exchanges? Thanks!
    • Quick Update - - -
      I had to take a little extra step, but thanks to the MyGrin Web Wallet (https://mygrin.org/) it worked now.
      BitForex could send it to the web wallet, and I could withdraw it into my local wallet (via ngrok to grin-wallet).
      Strange - but I’m happy now and I can do my little experiments with GRIN.
      I will donate a few GRIN to mygrin.org - awesome work guys. Saved my evening :smiley:
You could follow this article to build your own HTTPS address by Google cloud or Amazon for free
Maybe you could try my niffler’s hedwig relay :slight_smile:
Can you not use Poloniex, Bittrex ?
Looks cool, I will try it! Thanks!
OK I’m trying Hedwig now. ngrok is definitely blocked in China. BitForex cannot even reach me. I tested my setup and it works perfectly. Just to make sure I’m not stupid or anything.
I will keep you updated, if it works with Niffler.
Yesss, Niffler’s Hedwig works, can confirm! Great job.
