Buying Ipollo G1 Chips
Hey guys,
I am looking to buy several (30+) replacement iPollo G1 chips. It is my understanding that this model uses the 12nm FinFET asic chips but I am having challenges identifying if this is the correct chip type as well as if the 12nm FinFET chip is specifically adapted for the G1 model or if the chips are the same regardless of the hardware they are used in. Can someone clarify this for me, please?
In addition, does anyone have suggestions or leads on where I might be able to buy these chips directly?
Thanks!
Perhaps @Neo-Geo knows?
From my understanding, the G1 uses 30x chips, and the G1-mini uses 1 chip. Seems you could harvest these chips from G1 or G1-mini ASICs, or try to source them directly from iPollo, or single out the part (photograph markings) and contact various parts suppliers in China.
