Was geforce gtx 1060 (6Gb) and gtx 1080 (8Gb) - all worked (no errors in mining).
Removed gtx 1060 and replaced with gtx 1080 ti (11Gb) - OS saw only 1080 and it’s worked (no errors in mining);
Installed driver for 1080 ti - OS sees both but both cards not mining - error:
[INFO] [2019-08-26T21:32:14+03:00] Detecting platform
[FATA] [2019-08-26T21:32:24+03:00] CudaError: Unknown error: c:\windows\system32\nvapi64.dll
[WARN] [2019-08-26T21:32:25+03:00] Miner died! It will be restarted soon…
[INFO] [2019-08-26T21:32:32+03:00] Bminer: When Crypto-mining Made Fast (v15.8.4-3212522)
Steps performed on WIN 10 (64bit) and with bminer-v15.7.6-f585663 and v15.8.4-3212522
You need to uninstall the Microsoft Visual C runtime libraries and the recommendent 2015 libraries and with 430.39 it works than! The never version of the runtime libraries is giving this problem in combination with newer nvidia drivers!
Thank you for that sugestion mderoo75. Can you be a little more precise regarding which exact version of the runtime libraries Bminer requires? I removed all runtime libraries and added them back one at a time, but the problem persists.
I am having a hard time understanding why realbminer does not address this problem. It used to work like a charm before, but now a bunch of people are having problems with different unclear error codes
I still get strange errors with Bminer The latest release on win7 gives me the following error as soon as I try to launch one of the included bat-files:
@realbminer
Does Bminer work on AMD Radeon VII with Cuckaroo29Z? I see you have updated the miner for the new algo which is awesome. I am running ubuntu 20.04 and keep seeing this message.
“Undefined but requested solver: cuckaroo29z”
-Macker
