[ANN] AceMiner 1.2 Fast Grin Mimblewimble Cuckoo cycle miner for AMD/Nvidia
Ace Grin Miner v 1.2
We are developing a fast multi-gpu windows miner for cuckaroo29 mining algorithm which is used in Grin - a new community-driven implementation of Mimblewimble. Our miner provides speed advantage over competition and comes with a dedicated Discord support channel
Features:
  • Supports Nvidia/AMD GPUs with a min of 7gb VRAM
  • Simple configuration/auto-detection of GPUs and CPU settings
  • 4-6% speed improvement over grin gold miner
  • Ongoing development and dedicated Discord support channel
  • Moderate 1% dev fee to fund future development
  • Linux and Mac versions under development
  • Expected speeds for typical GPUs: 1080TI - 4.6 gps, 1080 3.6 gps, 1070ti 3.2 gps
Quick Launch Guide:
Update drivers: Nvidia just use the latest, AMD we recommend 18.6.1 adrenaline drivers[/li]
Download and install 2.2.1 .NET Core libraries Note: restart required[/li]
Set virtual memory to 40-56GB (about 7gb per GPU)[/li]
Run start.bat and input your pool data. We recommend the following pools: grinmint.com http://sparkpool.com
Download Links
AceGrinMiner_v1.2_windows_x64.zip
https://mega.nz/#!swN2jSoJ!LS87p5LSp2soB2YL7cqvcKv9ioRnhbLj5i5VBxIe-ks
Check integrity:
MD5: 84286D501C30CB1402BB7D49F09A0A5A
Contact Devs / Support
Please join us in the group where we offer early access to updates and online support.
We will help you start hashing in no time!
Great miner, nice stable, easy to use good UI. Loving it.
How did you manage that 5% speed-up with same SHA256 solver executable hash as the original solver executable? Genuinely curious.
Discord link not work.
Work now. Thanks
Hahaha… not gonna run it, but I suspect they have nice TUI in there, maybe something like this?
That’s some Mimblewimble magic!
I’ll give you cedit that you actually take only 1% dev fee total and do not steal passwords, however the solvers you are using are published under https://github.com/tromp/cuckoo/blob/master/LICENSE.txt so you might want to change that second protonmail account back to grincouncil@protonmail.com
Thanks, this makes sense, will do
For others reading this:
This is just 1:1 copy paste of GrinGoldMiner with the only change is changed the name (even that they screwed up, still reports as GGM in pools) and they take the fee for themselves. With that they are in violation of the fair mining licence.
Just use the original GrinGoldMiner (find it in GitHub), don’t fall for these cheap clones.
1)Like I said, we’ll comply
2)I guess it is for you to decide if you want to pay 2% or 1%+online support. You cannot possibly decide for everyone :slight_smile:
