Several people have reported huge amounts of bogus 2-cycles found on the CUDA cuckaroo miner running on a 2080 (Ti) GPU.
I’ve spent some time tracking down this issue, with ssh access to a 2080 GPU generously provided by Quentin & Blockcypher.
In the latest commit to https://github.com/tromp/cuckoo there is now a cudabug make target in the src/cuckaroo directory.
Running on a 1080 Ti, this gives:
$ make cudabug
nvcc -std=c++11 -o cuda19 -DSYNCBUG -DPROOFSIZE=2 -DEPS_A=4 -DEPS_B=3 -DIDXSHIFT=2 -DEDGEBITS=19 -arch sm_35 mean.cu ../crypto/blake2b-ref.c
./cuda19 -U 64 -Z 64 -z 64 -m 4
GeForce GTX 1080 Ti with 10GB @ 352 bits x 5505MHz
Looking for 2-cycle on cuckaroo19("",0) with 50% edges, 64*64 buckets,
4 trims, and 64 thread blocks.
Using 28MB of global memory.
nonce 0 k0 k1 k2 k3 a34c6a2bdaa03a14 d736650ae53eee9e 9a22f05e3bffed5e b8d55478fa3a606d
group 2f2 size 124
group 2f2 size 124 lid 22 localIdx 1
group 2f2 size 152
group 2f2 size 152 lid 18 nflush 8
group 2f2 size 152 lid 22 localIdx 0
Seeding completed in 1 + 3 ms
round 0 group ad6 edges 260
round 1 group ad6 edges 89
round 2 group ad6 edges 54
round 3 group ad6 edges 28
61340 edges after trimming
findcycles edges 61340 time 3 ms total 13 ms
Time: 14 ms
0 total solutions
The interesting output is right after “group 2f2 size 152”.
This is one of the 64*64 buckets being processed in the second call to SeedB. It contains 152 edges for which endpoint 0 has the least significant 6 bits being 0x0b. These edges are being bucket sorted on the next group of 6 bits. Those with the 12 lsb bits equal to 0x5ab will go to group 2d6.
There are 8 such edges, and they are “flushed” in lines 205-206 of mean.cu
Line 210 sets the counter for currently held 0x5ab edges back from 8 to 0, and there are no more edges to be moved in the leftovers loop at lines 215-227. On the 2080 however, thread 18 makes it to the leftover loop before thread 22 reaches the flush of 8 in the main loop, and it ends up storing these 8 edges twice in group 2d6:
$ make cudabug
GeForce RTX 2080 with 7951MB @ 256 bits x 7000MHz
Looking for 2-cycle on cuckaroo19("",0) with 50% edges, 64*64 buckets, 4 trims, and 64 thread blocks.
group 2f2 size 124
group 2f2 size 152
group 2f2 size 152 lid 22 localIdx 8
Seeding completed in 0 + 0 ms
round 0 group ad6 edges 268
61360 edges after trimming
2-cycle found
2-cycle found
2-cycle found
2-cycle found
2-cycle found
2-cycle found
2-cycle found
2-cycle found
findcycles edges 61360 time 3 ms total 4 ms
Time: 5 ms
Solution 64f04 64f04
FAILED due to edges not ascending
Solution 65124 65124
Solution 64b9d 64b9d
Solution 64d4d 64d4d
4 total solutions
The two __syncthreads(); calls in the main loop are supposed to prevent this. Or am I missing something?!
ADDENDUM: https://docs.nvidia.com/cuda/turing-tuning-guide/index.html mentions this new primitive __syncwarp for Turing:
“Applications that assume reads and writes are implicitly visible to other threads in the same warp need to insert the new __syncwarp() warp-wide barrier synchronization instruction between steps where data is exchanged between threads via global or shared memory. Assumptions that code is executed in lockstep or that reads/writes from separate threads are visible across a warp without synchronization are invalid.”
But that appears to be weaker than syncthreads; and the bug persists after changing to
__syncwarp(); __syncthreads();
Any thread syncing experts want to weigh in?
