yes it is there!! thanks mate!
That looks really awesome!
Awesome work @xiaojay ! Will try asap
is work with tor too ?
@Chronos Got time to do a 1 minute crypto video on what slatepacks are and what they do? Thanks!
tor will be supported in next version.
And windows version of niffler v0.6.0-preview is available now
well done.thank you.will it support multiple wallets in the future?
hey good job xiaojay
Great! Do you have a linux preview release too?
Hello there. Because I use google translate, what I wrote may not contain a proper grammar. I admire the manifesto of grin. I wanted to invest for him. I wanted to transfer the grin I bought from kucoin to niffler v6 wallet with hedwig. I did the necessary actions, but it was seen that the transactions were completed in Kucoin, but it did not come to the niffs even though I waited for hours. The number of blocks in niffs did not increase. I lost 100 dollars more. I did not share the transaction details as I did not know if it was dangerous. Could you help?
on the upright corner, try “more -> check balance”
if not show the tx, contact hobit
Niffler v0.6.0 released, with mac/win/linux support
I just installed this wallet. I made a small transfer to it and it worked. Really happy with it so far great work!
Good Job, bro.
I contacted Kucoin and returned my funds. Thank you very much for your interest.
Are all your remote nodes up? I receive errors again
This is great, as a newb to Grin I appreciate anything driven towards to GUI, as much as I was eager to learn about Grim, I found, as a newb, that it is really Linux focused giving it an even higher level of entry.
yes, one of remote node shutdown unexpected. sorry
now it started.
should be ok
if you are in european, maybe you cloud use @mcm-mike’s http://grinnode.live/ as remote node.
Yes I am in Europe. I read the instructions and solved. Thank you
