Can somebody with balance in his Niffler wallet send me a screenshot of how the wallet outputs a slatepack message? Just copy your own address, try to send to it, and take a screenshot when the wallet shows the slatepack. Then cancel the transaction.
mate I cannot access my wallet since update.
It tells me that I am entering invalid seed phrase.
But I am 100% sure its good. I´ve been recovering many times.
Now it doesnt work. Is there any issue on new wallet.
Cuz first I only updated the wallet, enter password but was unable to access.
So I have removed current and tried to recover after reinstall. Please let me know, thanks.
which os are you using? mac or windows?
send me log to xiaojay@gmail.com
the log located on ~/.niffler/log if you are mac;
c:/users/[your username]/.niffler/log if you are windows.
A bug fix/some improvement version of Niffler wallet v0.6.1, which update Grin node to v0.4.1;
And thanks to @Kinaou , French version of Niffler is available
Hi @xiaojay , I try to withdrawn grin from polo, using latest niffler.
I usred hedwig, and polo saids witradawn is completed, but on niffler i see that transaction, but is still unconfirmed, I did not close wallet, and green light is near hedwig.
Its been longer than 10 min and still not successfull, is this normal wait time or I should not use hedwig?
Edit: 3h+ passed, and still unconfirmed, ballance unchanged
I just saw my local node is not in sync, if I remove Current chain Data and sync from scratch will I loose this transaction its been 8h+ still no coins, its not finalized.
Thank you, but I think this has to do with network or something.
Firewall is allowed to niffler,
This is error I got in logs, and it keeps repeting
2020-10-16 22:58:15:719 [debug] hedwig succesful with url: https://9xxxxx432.v1.hedwig.im
2020-10-16 22:58:24:406 [debug] Try to test if http listen locally reachable?
2020-10-16 22:58:24:418 [debug] Http listen is locally reachable.
2020-10-16 22:58:24:427 [debug] Try to test internet reachalbe: https://9xxxx432.v1.hedwig.im ?
2020-10-16 22:58:25:497 [debug] receive data from hedwig
2020-10-16 22:58:25:718 [debug] connect https://9xxxxxxx34432.v1.hedwig.im return: Error: Request failed with status code 404
These are some SS from Niffler app https://prnt.sc/v15u91
Do you think if I try to restore my wallet with grin ++ can that transaction be ‘resumed’ over there?
EDIT: there are some changes, now Height (local): 393874 , before is 0.
But now when I go to Recive via Hedwig (becouse it saids it needs to be online) the address is different than the one from yesterdays one that coins were send to.
Can I change that to old address from yesterday, maybe coins can now reach my wallet and finish this transaction.
If there was a problem with building the transaction (hedwig/http) then you didn’t get the coins and you likely need to contact Poloniex about it.
But ye, before you do that I’d first suggest to restore your wallet and see if perhaps you did receive them. You can just download grin-wallet and use command grin-wallet scan, since you already have a grin node synced and running (if you do it via Grin++ you’ll have the sync the whole chain again).
I did the check ballance and nothing new happened.
If anything matters, height (local) is almost always 0, untill i downloaded grin ++, and when I turn on both wallets then height (local) gets big numbers.
Don’t run Niffler and Grin++ at the same time, it always causes issues. If you open Grin++, make sure the kill the grin node task that niffler runs in the background.
What do you mean?
Is your niffler wallet connected to a local or remote node?
Local node, default settings.
When I installed niffler, height was 0 all the time.
After trying all options and failed with niffler I downloaded grin ++, then the height automaticly goes big numbers.
Grin++ and Niffler interfere with each other in very annoying ways. I suggest you completely delete both of them, then re-download one. There’s probably another way to resolve the conflict, but it’s not as simple.
Alternatively, choose “Use remote all the time” and use https://grinnode.live:3413 as a remote node. See if that allows you to scan without errors.
Hello,
I tried to withdraw from Poloniex and send it to Niffler using Hedwig.
The transaction is confirmed, but the Unspent Output Commit is still unconfirmed after 1 hour.
