Testing is required for MWIXnet’s implementation of the Mimblewimble CoinSwap proposal in order to review, detect issues, and improve performance. That is a community effort, any participation help about instructing ,testing is needed & gladly welcomed.
First of all we need test coins. Do we have testnet coins any to send to testers ? _ @Mattczt , @navie
In the link are some instructions, not sure yet what needs to be tested.
Perhaps connecting multiple mixnodes? Probably we should try submitting multiple trx’s around the same time
Any suggestions for useful tests to run @Yeastplume?
After compiling with cargo build release
I get the error mwixnet command not found
No errors with the compilation, only some warnings about package not being supported in the future. Did anyone else get this error? Does it mean compilation did not work?
@grinmonk
I tried just now to compile on Ubuntu 22.04, I get the error: error[E0460]: found possibly newer version of crate core which num_traits depends on
Perhaps it means my version of rust is too new.
Tried fixing with cargo update, did not work.
Tried fixing by creating a rust-toolchain file specifying an older version for rust, now got a new error: found possibly newer version of crate core which cfg_if depends on
Maybe meaning that now the rust version I specify is too old
Solution
Problem turned out to be the default rust version on Ubuntu using rustup solved the issue:
curl https://sh.rustup.rs -sSf | sh
source "$HOME/.cargo/env"
Now I got a new error: failed to resolve: could not find write in core & could not find ‘fmt’ in core
@ardocrat did you encounter any trouble when compiling mwixnet?
Continuing the error party now while compiling on Windows:
--> C:\Users\anynomous\.cargo\registry\src\index.crates.io-6f17d22bba15001f\ntapi-0.3.6\src\ntexapi.rs:2785:52
2785 | *tick_count.QuadPart_mut() = read_volatile(&(*USER_SHARED_DATA).u.TickCountQuad);
= note: packed structs are only aligned by one byte, and many modern architectures penalize unaligned field accesses
= note: creating a misaligned reference is undefined behavior (even if that reference is never dereferenced)
= help: copy the field contents to a local variable, or replace the reference with a raw pointer and use `read_unaligned`/`write_unaligned` (loads and stores via `*p` must be properly aligned even when using raw pointers)
error[E0793]: reference to packed field is unaligned
--> C:\Users\anynomous\.cargo\registry\src\index.crates.io-6f17d22bba15001f\ntapi-0.3.6\src\ntexapi.rs:2809:25
2809 | ((read_volatile(&(*USER_SHARED_DATA).u.TickCountQuad)
error: failed to run custom build command for croaring-sys v0.4.6 error: could not compile ntapi (lib) due to 2 previous errors
For now I am unable to get this to work on Windows, will update if I find a solution.
Possibly you will have problems with chrono package as well, it’s cause grin_wallet_util used in project locked at 5.1.0-alpha.1, so only manual update or version specification at Cargo.toml helps.
With the two changes you suggested, I still get errors: croaring/roaring.h:39:10: fatal error: ‘stdlib.h’ file not found
CRoaring/roaring.h:39:10: fatal error: ‘stdlib.h’ file not found, err: true error[E0793]: reference to packed field is unaligned error: could not compile ntapi (lib) due to 2 previous errors
This is getting to much in errors discussion on the forum. I think I better discuss it with you on KeyBase until a solution is found. @grinmonk Can you check if you can get it to work with the proposed changes from @ardocrat?
NOTE:
This kind of grin dependency { git = "https://github.com/mimblewimble/grin-wallet", branch = "master" } will be updated to specific version after beta.5 release which will include croaring fix to avoid a lock of old version like it happened with grin-wallet dependency before.
