I send 3858 coins to TradeOgre, in my Grin++ wallet it was showing unconfirmed for allmost 24hrs, and on TradeOgre side it was showing pending, so I cancelled the transaction in Grin++. Now my coin are not in Grin++ nor in Tradeogre. I checked with TradeOgre support and they cancelled the transaction on their wallet.
If tradeogre didn’t receive your coins then you still have them, I’m not using grin++ but i would try cleaning data and syncing from start.
This is what Tradeogre says
Received Tx 92252873-b07e-453c-b0d1-24370be0e232 2023-10-24 14:42:28 None false None 0 1 3858.454276306 0.0 None 3858.454276306 None 09eb12e62d76e7702437edca34020f99f448c4c4d1dd3d6b01be02db154b46bcba None
- Cancelled
it is unconfirmed and cancelled in our wallet
I resynced the node, also restored from seed in another mobile wallet (ironbelly) still no coins
09eb12e62d76e7702437edca34020f99f448c4c4d1dd3d6b01be02db154b46bcba seems like kernel, this kernel doesn’t exist on chain, so if this kernel was used then you should still have the coins.
it is strange why 24h not confirmed… Cant connect node ?
Not a rare issue, when users complain about not confirmed txns on Grin++, trying to cancel and then struggling to find out where their coins exist.
my guess is the send did not go thru at all, but after i cancelled the unconfirmed transaction my coins were lost somehow. May be there is some bug in the wallet
Hey @tcj2001, this is a known bug in Grin++
, @davidtavarez is working on a fix.
Your coins are there, they are simply not shown properly in Grin++, they stay in the “locked-state” even thought they should not be.
The good news is you can simply get access to those coins by restoring your wallet from the seed.
The bad news is that you have to go through the hassle of restoring from seed due to this bug.
See here a link to the github issue:
but i already tried restoring from seed into another wallet and also restored into Ironbelly mobile wallet, both are not showing the coins
Tx not confirming 24 hour. This is problem imo, then cancelling the transaction.
That is quite mysterious. If the coins are not found after a restore when you waited for the node to fully sync, that means the coins were send successfully. However, with the transaction information you gave I cannot find a confirmed commit on the blockchain (using this awesome new block explorer. Did you cancel the transaction an try again or something? In such a case the transaction might have happened, but it would be with another TX ID and commit than the one you provided. Double check you copied the correct one.
I sent it only once and waited for 24 hrs, it was still unconfirmed, and on tradeogre side it was pending, so i cancelled the transaction in grin++. I contacted tradeogre about this, then they canceled the transaction on their end, ans send me this info
- Cancelled
Since you still see canceled transaction then you didn’t clean your data (if you sync from scratch without any data you never see canceled transactions). I’m assuming “kernels” is only a partial kernel, but anyway “kernels” is what’s needed to check if your transaction has been included in a block.
on the new wallet which was restored from seed, cancelled transaction is not there, this is from the original wallet that i sent the coin.
I was able to dig into the logs files and found some more infor can anyone make any sense out of it
[10/24/23 14:39:49.423+00:00] [info] [THREAD:140673539323648] Handle(42) - Sending slate: { “amt” : “3858454276306”, “coms” : [ { “c” : “08397b24dcf800433f210b40e8eef59ee1119e1722b7658398b7dc785b1afa3a23” }, { “c” : “0868fdbb7c8aae73e3f6431bff77786b5034b3f14bdd62b1637013dca2b41e4450” }, { “c” : “09c7140ca35fe5c656e401fa6c9b7763bfa2001151e80fdb0b28c76e0c13e626f0” }, { “c” : “08ae24c3b718a9cf08be0b1791ae4478e46285f0da69a64ce47dbd686c999aea8c” }, { “c” : “0896bdd7afed14be2338a311f3158a388d841e3d162b0affc3b9ee9bcfc9c987bd” }, {“c” : “086b8cd988ebdd2e79114a519aad9e57a8e753143f9815013f374189e5fa97300c” }, { “c” : “081c735d1911250bb88500e7f8698ef5edf690d48590f05839e85f3fedb94361f8” }, { “c” : “09395edbff8278c629da6dd3c45bfe8fbca26cd7e4f61ed167f7d56b68ab5f57a2” }, { “c” : “09ffbbca528a7a6f28c7e9c711d1aaf15eddbc0e6f2c5ef2329171d86e76f9bb53” }, { “c” : “085c1f101a9a688f53ea72aa4d61fc2f3a050b57def4eae8aba784c19f812e5224” }, { “c” : “08af5f80f4881bb8f3c375a1a6843dd9aa39d189985546c3ba0dcca4eaed747a26” }, { “c” : “09d3d9a5e6c66598014e89bdbeca1a735936f9508a6a4258953fb762038a6fcd29” }, { “c” : “0902d900a61b757bc4c64f7cc03554949e82605127762ac49cd9dfcd643dc41d1f” }, {“c” : “096f2978e63689be231b0bfb4aa8a5b9656cf8827302a639b455ef371ea81e64b5” }, { “c” : “08c1e337e032f8f3d79b2efb1c1d80db6f341d38220f888da92ab61a12f8d2a6e1” }, { “c” : “08cb3a17fe1db2a0645278c35db89d7abec6af5320a008126dbdb146f118cbc397” }, { “c” : “08a8dd5c579108d91113e4ca114aa46426f58d7067d01634a99f40c6e4a5d7facb” }, { “c” : “08680ce6daa29edcfb020d8b76652db5ecc95413ffccb5983cfb712c760c91470b” }, { “c” : “097483249a99c4252ec0466ff3c794ca5c4638b5780b0fb7ed533dad9b01c183c6” }, { “c” : “099d48a7e2ed4309f9095a1662254fc70ae5f133d931b9512c1f8c1002545fbc07” }, { “c” : “08bc3f8a59d1360d3db16a01e9188c3832d5f51c9f83f319b8a9dcef94debcc9dc” }, {“c” : “09bc19be61e7ed08d9a9f419d9fa04f4a6c93a8fdd2c75830dc5e347c168befc6d” }, { “c” : “098999577d3d914ba1ddb48d71f7b2f802ac006d69fc2b3eff3c3d4ecaecbc04bc” }, { “c” : “09e048674994c34f0c379deb0990a4fbb144da8bd25145686c7ed6986d225049d3” }, { “c” : “09295705d12fa19150f32225dce4fc3ffdc8633efc93dffd48ca7240ba73efe2a1” }, { “c” : “08a8a8f6c98b0bb213c32f08f3cf02c28d7562d48cb889f014a53385f9bdf7f1ad” }, { “c” : “09bfb53d4f2684bfd797ef199716b7a049471176d68bd3153f17bee61e99f437e2” }, { “c” : “087439d92d2cc173b38e799ac443d02e879bf9a5e3682144596be812afd6482b23” }, { “c” : “091fcc14a612319d25777753500bcf2fc68055b49009bb25079481ad35d7d91b35” }, {“c” : “08b8780fe425a98e9c75705f8392f6834a73eb444cda9e624086a681084b57e3d7” }, { “c” : “083d995850fb2672c5f5fcff588d013183ddd11d02df2c44a2fdde2044d504b4ab” }, { “c” : “087f126c513cfc7813fbbc6ad14c98c3f723227b8d611662eececdd3de32c834b1” }, { “c” : “09da7ac5755e536059980b84e438d9d80907bdc015003d1a2777c238c082c2c228” }, { “c” : “09f6b818b934dbcd16694b264e7d1126a7caaab60a028c85445eb3afe094f37724” }, { “c” : “0882efd33b3921af96da9f18018607e3bd5394a5db1e3c877b00d978e3cb591e8d” }, { “c” : “094916ef400f85a968540815421dbf59e5ad7c9e06b216bc41a76371d906b51238” }, { “c” : “0955479009ea29827ceb29b11e32a52ef9c3f1c97daa201df92e49c096179f7e63” }, {“c” : “09d8b1c0fd14044695ca27a8ea434f856aaf4d129e3d04c1c2016aecd9a78f3689” }, { “c” : “085f5cc828efe9b9a79f3dae6055c41faf889229d2d91caac9ecb97a298de8d3e0” }, { “c” : “08b7d76805ae0a782bee9242d8f27a77004750874c1662e44f28828a14d2aace94” }, { “c” : “0973256007e54bdf34374ba02aed6dccfed93536fda51046b599bd8deb521b8398” }, { “c” : “080d24a046999363302d17602fda4f63f5fa5d7097fd8664cc76b2d9f207ecaeb7” }, { “c” : “08dad3fbef1c224720fec778d1f44bd3d3eb085f6baf949c653d12eb432f23a867” }, { “c” : “09cb1709853edace5c25108149ffcc51ebc8153354916a802f68f65a3620086c8d” }, { “c” : “08526b50170db17d27a3449bc646b1e4f62da452612fa323f6fef8f13c20972192” }, {“c” : “08a69e8c247bc03c156cd0219a8206987c908adc74a5e68a73d09dfbaa01b0b09c” }, { “c” : “08e59347720b759164a40f66ac62f81d69d5040a0a4b11dbbbfbfd8c3f9fdc1c0a” }, { “c” : “0944372d74b639d5ff45ff67ca043d806ce7602e9db54b7382452fc7e186b64c27” }, { “c” : “08a432ccb68370f5e345fa5019c546c195151c33c913497d0cde6735dd06cc5eba” } ], “fee” : 36500000, “id” : “92252873-b07e-453c-b0d1-24370be0e232”, “off” : “aaf2ded7bba211be5e4ab9b80ee945e014ad87283ddce5d0157b872148c11f2d”, “sigs” : [ { “nonce” : “03737f0d3bb869dbea7538c36f3277abdc52b5bac9911ad9d3253fdd42e80127a5”, “xs” : “03cb0ab8d4810891c7e18ef8509c63c6bc8c7e905efbd89560a417a1d89a1418a2” } ], “sta” : “S1”, “ver” : “4:5”}
Is this Grin++ team support channel?
Telegram: Contact @GrinPP #minimum character limit
This sounds like the same issue I had and made a rant/flame about. Eventually @davidtavarez worked with me for about a month on the issue before just giving me grin out of his pocket. He did not fix the issue. Sounds like this bug will remain and Grin++ is unstable / unsafe to use, correct me if I’m wrong, thanks.
That’s correct. The fix is being tested on this PR here Hotfix (test): Ignorting initial status of slate while trying to finalize by davidtavarez · Pull Request #234 · GrinPlusPlus/GrinPlusPlus · GitHub
I’m very close to finally solve this.
