The issue_send_tx in the original V1 API essentially did too much, creating a (sender-initiated only) transaction and posting it via HTTP all in in one go. In the V2 API, this was broken up into more granular API functions.
You can replicate this functionality in the V2 API by providing a send_args parameter in the call to the V2 init_send_tx as follows:
"jsonrpc": "2.0",
"method": "init_send_tx",
"params": {
"args": {
"src_acct_name": null,
"amount": "1000000000",
"max_outputs": 500,
"minimum_confirmations": 10,
"num_change_outputs": 1,
"selection_strategy_is_use_all": true,
"message": "my message",
"target_slate_version": null,
"send_args": {
"method": "http",
"dest": "http://127.0.0.1:3415",
"finalize": true,
"post_tx": true,
"fluff": true
The workflow will then be exactly the same as the V1 issue_send_tx, with the send, locking, finalizing and posting operations operating subsequently and returning an error if there’s an issue during any one of them.
If you’re calling the API functions separately, the workflow would be something like this:
- Call
OwnerAPI::init_send_tx(withsend_argsset to null), and get a slate back - Exchange the slate with the other party (who will call
ForeignAPI::receive_txon their foreign API, regardless of whether it’s HTTP or file exchange) - Once the caller is happy that the other party has received the transaction (if sending via HTTP) or the output file has been created ready for sending, call
tx_lock_outputswith the Slate, which is required before the next calls will work. - Call
finalize_txwith the slate received from the other party - Call
post_txwith the transaction in the slate.
The most important things to note here are:
tx_lock_outputs, which locks the sender’s outputs so they won’t be used in further transactions is not called automatically anywhere (except if you providesend_argsin the call toinit_send_tx(orinit_invoice_tx) -
post_txis not automatically called anywhere, (except for the case where it’s specified insend_args)
Would appreciate if anyone wondering about these can let me know if this helps, if not I can refine with more/clearer information.
