Happy I found this site. And it seems to be a very active community which is a good thing.
I am somewhat of a noob to mining (not completely) but still testing/figuring things out.
I was using Cudo Miner to mine Grin, which was -eh-. And after playing around with other coins, I think I can do much better with a pool.
I started the sequence with the instructions from this forum to install on a Mac.
The server portion is up and running but the wallet fails to initialize.
I’m received this error: -bash: grin-wallet: command not found.
Any ideas of what’s wrong or how to fix it?
Thanks
Humm that did not work either if you mean local as in from user folder (on Mac).
When I enter the command it asked for password, once that was entered in tried to run then Error could not open. Run grin wallet init.
Thanks though. Trying anything and see.
If you want a more easy to use interface Grin Wallet, Grin++ is great. Mining on https://thegrinpool.com/ and withdraw my funds to Grin++. What’s great is I can always restore my wallet using the grin-wallet or wallet713 if i want to switch back to terminal wallet.
