How do I restore GRIN on Vite phone wallet with a seed?
Is there a way to restore GRIN on a Vite phone wallet? If this is not possible how do I restore the see on the Web wallet? Thanks. RG
I assume this is the APP you are talking about?
I assume it works like any other crypto wallet where once you install the APP you are asked to either a) create a new wallet or b) restore an older wallet by entering the mnemonic seed phrase you have written down.
Why do you need to restore?, if the APP is installed on your phone and you forgot the password or pin, I would advise to make a backup of the phone APPs and data in any case before trying to reinstall.
