about 25% growth in a day , wow that’s alot! not sure if it’s related to bminer update to version 3 or many more people are jumping in ,what do you think
also where can i find network hashrate by pool? lost that website
Thank you dude! …
Edit: it’s broken , is there any other site?
From the grin server,
it’s not 25%. it should be around 45% from yesterday. crazy.
That looks incorrect, as if its graphrate estimation is still assuming Cuckaroom’s solution rate of 1/42, while the correct rate for Cuckarooz is 1/84.
And where is the correct hashrate? i mean where we can follow?
I don’t know any other explorers showing graphrates.
I used to visit https://grin-fans.org/en/ but my browsers consider it unsafe now.
There is grinmint API here https://api.grinmint.com/v2/networkStats
Yes Grinmint is showing network Hash rate perfect. But why it’s lower than a single pool f2pool Hash rates
https://miningpoolstats.stream/grin-c29
https://www.f2pool.com/
F2Pool reports the network hash rate correctly. However their own hash rate is incorrectly reported.
Yes if it’s incorrect fine and they need to correct…
