Dear Vite mobile wallet fans,
Vite Multi-Chain Wallet will halt services for GRIN on July 11 16:00 (UTC+8) for upgrading to Grin Wallet v2.0.0. After the upgrade, Vite Wallet won’t support transactions from Grin wallet lower than v2.0.0.
Details:
We will release the new version of Vite Wallet after the upgrade, which is estimated to be between 12 and 14 July. After that, to continue to send and receive GRIN in the Vite Wallet and to avoid any loss of your GRIN asset, you have to update your Vite Wallet to the latest version in App Store.
Notice:
A. For the balance during the upgrade
Your balance is only related to your mnemonic words, you can find your balance in any wallet (such as Grin command wallet and others) supporting Grin v2.0.0 with your mnemonic words imported.
B. For GRIN received by Vite gateway during the upgrade
If there is any GRIN received by Vite gateway, Vite gateway will keep your GRIN until the upgrade ends and send to you after the upgrade. So, please do update your Vite Wallet to the Latest version right after its release, in case problems in receiving the transactions.
C. For wrong balance after update:
- Please make sure you have updated to the latest version.
- Please make sure the full node connected is v2.0.0.
- Try importing mnemonic words or checking again.
Should you have any problem please feel free to contact us.
Thanks for your understanding.
Vite Grin Mobile Wallet
