Grin node Win10 - does not start after possible computer reboot
Hello, Grin tech people.
I was running grin-v1.1.0-win-x64.zip for the past few days with no problems - computer restarted a few times but the node started by itself with no problem
Today I could not start the node - cmd screen flashes with this error:
I noticed on Linux there are some commands to fix it - is there any equivalent in commands in Win10? files that I have to delete to get the node running again?
It’s hard to trace the error without the log, may you share your grin-server.log?
C:\Users\ user \ .grin\main
Try delete .api_secret first
deleting .api did not work.
I fix it by deleting the whole C:\Users\ user \ .grin*.* content and started new sync.
Sometimes I forget how light the ledger is - 1.7 GB… meh it will sync pretty fast.
Cheers
Thanks for pointing the log file - I look at it but I could not make to much of it. So I have deleted the whole .grin folder and started a new sync.
