Grin node on rasoberry pi
Hi
I was able to run grin (node) on a raspberry pi.
This is a good set up since I only use the pi, a 16gb sd card and a 15w power supply.
No multi GB SSD drive, no high end internet connection.
Turns out the “cargo” tool builds the executable without any issues. Rust rocks!
I used an 8gb ram rpi4, but I believe even a 2gb ram rpi can run it.
I hope more people can run their node, so wallets like ironbelly can be used with people’s own nodes.
Here is the video I made
Pd: anyone know if there’s a date for grin software on HW ledger x?
Cheers
Grin runs great on Raspberry Pi. 8GB versions does give a more smooth experience than 4 or 2 GB. I use the Raspberry Pi 400 (keyboard and Pi in one with some 20% performance boost).
Ledger support is there, but not official or reviewed yet, see status:
This is fantastic. A well put together tutorial, thank you.
Regarding Ledger, I believe that Nicholas Flamel has requested more money to continue the work and I don’t know what the outcome of that is yet.
Awesome video, I like the scrolling text document touch.
Was wondering about this, and if anyone has tried setting up a Grin node on a cloud server.
I believe it can be done. I would compile the binary in another linux machine though ( a machine with more resources, because the compilation is cpu intensive). I would try a 2 core 2 gb ram vps. That may cost from 5-10 usd/mo.
But I am only guessing.
My node runs on a vps - ubuntu 22. I use it for mining and as Grin wallet.
Small warning, latest versions of Ubuntu run slow on Raspberry Pi and require additional tweaks to make it not too slow. If anyone has a particular good experience with a Linux flavor on the Pi that also does well compiling all grin binaries, please share it here.
Thank you for the detailed tutorial. I need to setup a node. Currently I have a Bitcoin node on micro PC (i5 based), so many free resources available. Grin is the way
Hi! Do you know how much hard drive space is required to run a node?
chain_data of prune node takes around 4GB, and chain_data of full archive node around 14GB.
1st time run: grin server config
This will generate a grin-server.toml file in the current directory. Edit file grin-server.toml, remove # before archive_mode = true
I imagine that this size grows as the blockchain grows too? If so, do you know by how much?
It took 5 years to get those sizes, you can multiple the years to estimate (I think)
After 20 years it will be server desk
Thanks for the great tutorial, @xphis05! Just built grin on a Rock 4 SE with 4gigs without issue.
