Does anyone have any experience with Grin miners pushing only barely above half of their normal hashrate? I have several G1 minis now doing that. Using 2miners.
Any ideas how this gets fixed?
I’m dealing with 57 minis and I also use 2miners, and none have ever hashed low, not even when parked in the attic during the summer with a failed fan or two. You could try upgrading to the latest firmware by SD card. You can download the latest firmware here.
Look at the current and average hashrate pool side. A mini could report low temporarily, but those averages should be as expected.
If I remember correctly this problem although rare, has been reported before. I think because the chip was damaged or only working half. Make sure you are not using some custom setting though, those could also limit your hash rate. For example, if you lower the maximum temparature, expect a lower hash rate (be sure not to put it higher than allowed or you will fry your G1 mini).
Reported before here:
Some pools differs really, from 1.2 kgps to 1.6 kgps at same time for me, oveall hashrate considered with this. I dont know if it is a pool thing, i simultaneously swtiched from pool to pool at shortest time. I will test it somehow.
Guys, thank you for your responses. I will try updating the firmware. I currently have 2.49.
I have a feeling this is pool related. Here are details of my experience
This absolutely doesn’t look like a firmware, environment, power or software issues. I strongly believe it is an issue with 2miners.
Regardless, I will update them and see what happens. Then if that fails, I’ll try a different pool.
Any pool suggestions?
