Is there a way to manually select Inputs/UTXOs to spend, or to simply create raw transactions like in Bitcoin?
what do you mean by ‘like in Bitcoin’? Can you be a bit more specific?
There are no addresses. Instead blinding factors are used.
In Grin you cannot simply send coins somewhere. The receiver needs to sign as well.
That means that you can only create transaction to yourself non-interactive.
But such transactions can be computed locally and then broadcasted (like in Bitcoin).
I admittedly have to look deeper into txs. The thought of UTXOs being combined/tied together is what prompted me to ask, something I would have liked to prevent with manual selection. Also, in creating a raw tx in bitcoin, I could set my fee. Is there a way to do so with Grin?
