I am a grin newbie. My computer is an acer c720p running galliumos 2.1, which is essentially Ubuntu 16.04 customized for the hardware.
Today I downloaded the grin v3.0.0 tar file from github and extracted it in my home folder. I also added an export PATH command in bashrc.
When I open a terminal and type “grin”, nothing happens. A new command prompt simply pops up immediately. This happens regardless of whether I am in the grin directory or elsewhere.
Searching the forum turns up a thread from one year ago with the same question.
The OP garnered a single reply, asking if there’s a grin-server.toml file anywhere.
My installation doesn’t seem to have such a file; I only see the grin file itself. Since the aforementioned thread is a year old, I don’t know if the information in it is useful, but thought that I ought to mention it.
I would really like to get my node going because I like Grin and think it’s a great coin. Is there somebody who can help?
The config subcommand generated the .toml file and some others, e.g. /grin/chain_data/lmdb/data.mdb. But the commands “grin” or “grin server run” exit to a command prompt, as before.
Am I supposed to be doing something with the options, like specifying a port?
No; you shouldn’t need to specify any options. Can you clear the grin-server.log file, rerun and post contents here if not too long (else give link to a paste somewhere) ?
After deleting the log file contents, and then running “grin”, this is what the log file contains:
20200214 21:45:26.182 INFO grin_util::logger - log4rs is initialized, file level: Info, stdout level: Warn, min. level: Info
20200214 21:45:26.182 INFO grin - Using configuration file at /home/a/grin/grin-server.toml
20200214 21:45:26.182 INFO grin - This is Grin version 3.0.0 (git v3.0.0), built for x86_64-unknown-linux-gnu by rustc 1.39.0 (4560ea788 2019-11-04).
20200214 21:45:26.182 WARN grin::cmd::server - Starting GRIN in UI mode…
20200214 21:45:26.182 INFO grin_servers::server - Starting server, genesis block: 40adad0aec27
20200214 21:45:26.183 INFO grin_store::lmdb - Resized database from 1048576 to 134217728
20200214 21:45:26.279 ERROR grin_util::logger -
thread ‘main’ panicked at 'called Result::unwrap() on an Err value: Chain(Error { inner:
Other Error: output vs rproof MMRs different sizes })’: src/libcore/result.rs:1165stack backtrace:
0: grin_util::logger::send_panic_to_log::{{closure}}::hff21834a86023c70 (0x55f22188bd21)
1: std::panicking::rust_panic_with_hook::h825f041245da8739 (0x55f2219c38ac)
at src/libstd/panicking.rs:477
2: std::panicking::continue_panic_fmt::hbe0378e33481e81b (0x55f2219c3362)
at src/libstd/panicking.rs:380
3: rust_begin_unwind (0x55f2219c3256)
at src/libstd/panicking.rs:307
4: core::panicking::panic_fmt::h527855ce0bc891f6 (0x55f2219e119a)
at src/libcore/panicking.rs:85
5: core::result::unwrap_failed::ha8b77e6004f0ba38 (0x55f2219e1297)
at src/libcore/result.rs:1165
6: grin::cmd::server::start_server_tui::h60bb15ef21638c5c (0x55f2211b5070)
7: grin::cmd::server::server_command::h489e4b6c04796d86 (0x55f2211b5c15)
8: grin::real_main::h4a47aac0e709af64 (0x55f2211e0394)
9: grin::main::h8d53dbda0218ff7d (0x55f2211deae6)
10: std::rt::lang_start::{{closure}}::h63635ad4e997182b (0x55f2211acc93)
11: std::rt::lang_start_internal::{{closure}}::ha04574f12d97cbe2 (0x55f2219c31f3)
at src/libstd/rt.rs:49
std::panicking::try::do_call::h7c2a8488f72db90c
at src/libstd/panicking.rs:292
12: __rust_maybe_catch_panic (0x55f2219c8e1a)
at src/libpanic_unwind/lib.rs:80
13: std::panicking::try::hc3a9b5da4250385d (0x55f2219c3cbd)
at src/libstd/panicking.rs:271
std::panic::catch_unwind::hf27600bf8c37809a
at src/libstd/panic.rs:394
std::rt::lang_start_internal::h409d4f2fe51133b0
at src/libstd/rt.rs:48
14: main (0x55f2211e0ab2)
15: __libc_start_main (0x7f681a428830)
16: _start (0x55f221176a39)
17: (0x0)
I went through the entire chain_data directory structure and deleted every file (including the blockchain), while leaving the .toml file untouched and the empty folders themselves, i.e. the directory structure intact. Still doesn’t want to run. On first attempt, it says “illegal instruction” and exits to command prompt. On second attempt, it just exits to command prompt.
a@galliumos:~/grin$ grin
Illegal instruction
a@galliumos:~/grin$ grin server run
a@galliumos:~/grin$
All the files that I deleted appear to have been repopulated.
By the way, the path looks a little different than what you wrote. It’s like this, with no “main” folder
/home/a/grin/chain_data/
And there is a text file, /home/a/grin/chain_data/grin.lock which is blank.
The same problem (can’t start the node) I met today:
20200324 21:59:33.315 INFO grin_util::logger - log4rs is initialized, file level: Info, stdout level: Warn, min. level: Info
20200324 21:59:33.315 INFO grin - Using configuration file at /home/rabinovitch/Grin/grin-server.toml
20200324 21:59:33.315 INFO grin - This is Grin version 3.1.0 (git v3.1.0), built for x86_64-unknown-linux-gnu by rustc 1.41.0 (5e1a79984 2020-01-27).
20200324 21:59:33.315 WARN grin::cmd::server - Starting GRIN in UI mode…
20200324 21:59:33.315 INFO grin_servers::server - Starting server, genesis block: 40adad0aec27
20200324 21:59:33.315 INFO grin_store::lmdb - Resized database from 1048576 to 134217728
20200324 21:59:33.363 ERROR grin_util::logger -
Other Error: output vs rproof MMRs different sizes })’: src/libcore/result.rs:1188stack backtrace:
at src/libstd/panicking.rs:475
2: rust_begin_unwind
at src/libstd/panicking.rs:375
3: core::panicking::panic_fmt
at src/libcore/panicking.rs:84
4: core::result::unwrap_failed
at src/libcore/result.rs:1188
5: grin::cmd::server::start_server_tui
6: grin::cmd::server::server_command
7: grin::real_main
8: grin::main
9: std::rt::lang_start::{{closure}}
10: std::rt::lang_start_internal::{{closure}}
at src/libstd/rt.rs:52
11: __rust_maybe_catch_panic
at src/libpanic_unwind/lib.rs:78
12: std::panicking::try
at src/libstd/panicking.rs:270
at src/libstd/rt.rs:51
13: main
14: __libc_start_main
15: _start
20200325 08:28:47.728 INFO grin_util::logger - log4rs is initialized, file level: Info, stdout level: Warn, min. level: Info
20200325 08:28:47.728 INFO grin - Using configuration file at /home/rabinovitch/Grin/grin-server.toml
20200325 08:28:47.728 INFO grin - This is Grin version 4.0.0-alpha.1 (git v3.1.1-test_no_compat.2), built for x86_64-unknown-linux-gnu by rustc 1.41.1 (f3e1a954d 2020-02-24).
20200325 08:28:47.728 WARN grin::cmd::server - Starting GRIN in UI mode…
20200325 08:28:47.728 INFO grin_servers::server - Starting server, genesis block: 40adad0aec27
20200325 08:28:47.728 INFO grin_store::lmdb - Resized database from 1048576 to 134217728
20200325 08:28:47.817 ERROR grin_util::logger -
7: grin::real_main
8: grin::main
13: main
15: _start
