How long to solve block @0.02 GPS
Got my old cpu running finally, and have 1 Solution accepted, just wondering with this kind of horsepower (0.02 GPS) how often would i expect to solve a block, if ever?
thanks
There is a writeup on the mining section that might help you out.
thanks for pointing that out, a little technical for my brain, i’ll try again tomorrow after i have had some sleep!
cheers
