GrinHelper Suite - Bash Script Repository
A Bash script repository to manage your local and remote Grin nodes, wallets, logs, …
Installation instructions
- Get yourself a clean Ubuntu or Debian (tested working on Ubuntu 16.04 LTS minimal)
- Run this command in a terminal
wget --no-check-certificate --quiet 'https://raw.githubusercontent.com/dewdeded/GrinHelper/master/Install.sh' > /dev/null 2> /dev/null && bash Install.sh
GrinHelper.sh
This bash script manages your local Grin node.
Features
This is what this script will do for you.
Automatic setup
- Install Grin depencies: Clang-3.8, Rust 1.21, rustup
- Install it’s own depencies: figlet, screen, jq
- Install Grin
- Autofix logfile size
Launcher and corresponding logviewer
- Start detached Grin Wallet (Testnet1)
- Start detached Grin Mining Node (Testnet1)
- Start detached Grin Mining Node (Testnet2)
- Start detached Grin Non-mining Node (Testnet1)
Logviewer
- Check logfiles of Grin Wallet
- Check logfiles of Grin Node
Show funds, transfers and stats
- Show balance of local Grin wallet
- Show outputs of local Grin wallet
- Show sync & mining statsof local Grin Node
Monitoring, operations and update
- Check which Grin processes are running
- Check Grin Connectivity - Check if Grins ports are publicly reachable.
- Stop Grin processes (Killall Grin processes, Kill Grin Wallet, Kill Grin Node)
- Update GrindHelper
- Update Grin (to latest version in master-branch.)
Extras
- Small fixes for current master (e.g. missing/wrong entries grin.toml)
- more to come
GrinHelper-Remote.sh
This script manages, monitors and aggregate status info from remote Grin nodes.
Functions
- Check Sync & Mining Stats (at all remote nodes)
- Check Outputs (at all remote nodes)
- Check Balance (at all remote nodes)
- Check Connectivity (off all remote nodes)
- Update GrinHelper (on all remote nodes)
