Hey guys,
Running a fresh grin build with grin-wallet and grin-miner on Ubuntu 18.04 LTS. Grin node runs fine, wallet is listening, grin-miner is mining into the wallet correctly, and port forwarding and ufw have been set up.
I’ve been trying to request some test grin from gringod.info but get the following error:
Wallet command failed: LibWallet Error: LibTx Error
Any idea how I can troubleshoot and fix this? Thanks in advance!
Here’s the full output of the ‘curl gringod.info’ command:
john@server-ubuntu:~/crypto/grin$ curl gringod.info ## Gringotts is smiling on you today. Sending 2.364 grin. ## 20181225 09:33:58.950 INFO grin_util::logger - log4rs is initialized, file level: Error, stdout level: Debug, min. level: Debug 20181225 09:33:58.950 INFO grin - Using wallet configuration file at /home/gringod/.grin/grin-wallet.toml 20181225 09:33:58.950 INFO grin - This is Grin version 0.4.2 (git v0.4.2-89-g84d2966), built for x86_64-unknown-linux-gnu by rustc 1.33.0-nightly (09d6ab90e 2018-12-20). 20181225 09:33:58.950 DEBUG grin - Built with profile "release", features "". 20181225 09:33:58.950 DEBUG grin_wallet::types - Using wallet seed file at: /home/gringod/.grin/wallet_data/wallet.seed 20181225 09:33:58.958 INFO grin_wallet - Using LMDB Backend for wallet 20181225 09:33:58.958 DEBUG grin_wallet::types - Using wallet seed file at: /home/gringod/.grin/wallet_data/wallet.seed 20181225 09:33:58.983 DEBUG grin_wallet::libwallet::internal::updater - Refreshing wallet outputs 20181225 09:33:58.995 DEBUG grin_core::libtx::build - Building input (spending regular output): 2575015000000, 0300000000000000000000004700000000 20181225 09:33:58.995 DEBUG grin_wallet::libwallet::internal::selection - Building change outputs: total change: 2572647000000 (1 outputs) 20181225 09:33:59.004 DEBUG grin_core::libtx::build - Building output: 2572647000000, Commitment(08580a7c7a8d6c3031b9cb784ba701d6ddd04c244149664af7c7190a16bec59ef2) 20181225 09:33:59.062 INFO grin_wallet::command - Tx created: 2.360000000 grin to http://109.236.133.220:13415 (strategy 'all') 20181225 09:33:59.062 DEBUG grin_wallet::adapters::http - Posting transaction slate to http://109.236.133.220:13415/v1/wallet/foreign/receive_tx 20181225 09:33:59.263 DEBUG grin_wallet::types - Using wallet seed file at: /home/gringod/.grin/wallet_data/wallet.seed 20181225 09:33:59.307 DEBUG grin_wallet::types - Using wallet seed file at: /home/gringod/.grin/wallet_data/wallet.seed 20181225 09:33:59.331 DEBUG grin_core::libtx::slate - Validating final transaction Wallet command failed: LibWallet Error: LibTx Error john@server-ubuntu:~/crypto/grin$
