Any xp how to update the node version on linux? I tried to remove the .grin folder but grin command instant restore it. Is there a way to update via command line?
As far as I understand, if you update, you only need to replace the binary. You do not even need to remove the ./grin folder.
So I think it is as simple as 1) removing the grin binary file/executable 2) going to the github page, downloading the .zip or .tar file and extracting it, in which you will find the grin binary.
running the binary which is now the latest version means you updated. In case this gives you errors, just remove the ./grin folder and try again.
In case you need to compile your own version of the wallet and node for and ARM chip, read below
On custom linux ARM chip, e.g. Raspberry Pi
1) Install rust
sudo curl --proto '=https' --tlsv1.2 -sSf https://sh.rustup.rs | sh
-Restart command line to upload your path variabel, otherwise cargo build will not work
git clone https://github.com/mimblewimble/grin
cd grin
cargo build
Look in /target/release to get the binary file (grin), copy it to a convenient place such as your home folder, this is the node binary, run via command line ./grin
3) Now install the grin-wallet
git clone https://github.com/mimblewimble/grin-wallet
cd grin-wallet
cargo build
Look in /target/release or in case of errors in /target/debug to get the binary file (gin-wallet), copy it to a convenience place, this is the wallet binary,
-run in listening mode for incoming transactions with: ./grin-wallet listen
-Or if you do not have a wallet yet: ./grin-wallet init
-Or if you need to recover from seed: ./grin-wallet init -r
Thanks for help. In my case it worked to download latest version from github and add it to
tar -C /usr/local/bin -xzf grin-$VERSION-linux-amd64.tar.gz --strip-components=1
A reason for TUI freeze is starting the server at main thread, I experienced same problem at my app, it can take up to 1 minute at debug release to start the server with finished sync state, problematic call is: chain::setup_head.
At my app I just moved server creation to separate thread to avoid this, discussed this problem with @vegycslol also, I guess we can solve it by launching server at another thread or optimize setup_head function somehow.
P.S. At my build I used 5.1.2 too as last available version from crates.io
