I’m running 22.04.2 LTS and I get this error:
grin: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.32' not found (required by grin)
grin: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.33' not found (required by grin)
grin: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.34' not found (required by grin)
but also:
libc6 is already the newest version (2.31-0ubuntu9.9).
So do I need to upgrade ubuntu to a newer version?
Try to install all deps:
apt install build-essential cmake git libgit2-dev clang libncurses5-dev libncursesw5-dev zlib1g-dev pkg-config libssl-dev llvm
# Grin - Build, Configuration, and Running
*Read this in other languages: [Español](translations/build_ES.md), [Korean](translations/build_KR.md), [日本語](translations/build_JP.md), [简体中文](translations/build_ZH-CN.md).*
## Supported Platforms
Longer term, most platforms will likely be supported to some extent.
Grin's programming language `rust` has build targets for most platforms.
What's working so far?
* Linux x86\_64 and macOS [grin + mining + development]
* Not Windows 10 yet [grin kind-of builds. No mining yet. Help wanted!]
## Requirements
* rust: Install using rustup: https://rustup.rs
* Grin currently does not support a minimum version of Rust, it is recommended to build using the latest version.
* If rust is already installed, you can update to the latest version by running `rustup update`.
* clang
This file has been truncated. show original
This machine was already running the alpha so I think I have all those but I’ll try reinstalling them.
Dependencies were indeed already all installed.
Upgrading to 20.04.6 LTS fixed it!
Wait no I’m back on 22.04.2 LTS I don’t know what I’ve done lol.
I ran sudo do-release-upgrade -d and followed through all the prompts.
Indeed last build requires GLIBC 2.32+ and not launching at distros like Debian 11, as it comes with 2.31 by default.
From forums:
If you need to upgrade glibc, the safest solution may be to upgrade your Linux distribution, since most software depends on glibc.
I guess the problem is coming from CI, build changed since May, so it depends on recent LIBC for now:
Another solution is to build your own grin binary against GLIBC you need to use.
This problem is old:
opened 08:22PM - 10 Jan 19 UTC
closed 09:17PM - 17 Jan 19 UTC
O-linux
When rustc builds on a system with a recent glibc version, the binaries require … a recent glibc version (2.18). When built on an old system however, they will only require glibc 2.3.
To reproduce we can use a simple hello world example, building e.g. on Ubuntu 18.04:
cargo new hello-world
cd hello-world
cargo build --release
Let's look at the required symbols, filtering out glibc 2.2 and 2.3:
$ readelf -Ws target/release/hello-world | grep GLIBC | grep -v GLIBC_2.[23]
11: 0000000000000000 0 FUNC WEAK DEFAULT UND __cxa_thread_atexit_impl@GLIBC_2.18 (5)
47: 0000000000000000 0 FUNC GLOBAL DEFAULT UND memcpy@GLIBC_2.14 (12)
537: 0000000000000000 0 FUNC WEAK DEFAULT UND __cxa_thread_atexit_impl@@GLIBC_2.18
644: 0000000000000000 0 FUNC GLOBAL DEFAULT UND memcpy@@GLIBC_2.14
We see that 2.14 and 2.18 seem to be used. We can confirm that those symbols are indeed required using a cent os 5 docker container:
$ docker run --rm -v $(pwd)/target:/root/target -it quay.io/pypa/manylinux1_x86_64 /root/target/release/hello-world
/root/target/release/hello-world: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by /root/target/release/hello-world)
/root/target/release/hello-world: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /root/target/release/hello-world)
This happens even with cent os 7:
$ docker run --rm -it -v $(pwd):/io centos:7 /io/target/release/hello-world
/io/target/release/hello-world: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /io/target/release/hello-world)
When building inside the cent os 5 container on the other hand, none of the above symbols are used and the binary runs just fine in the container.
### Why does this matter?
For my case, it's because I want to produce [manylinux](https://www.python.org/dev/peps/pep-0513/) compliant libraries and binaries. manylinux is a policy defined by python designed to be compatible with virtual any used linux system, which requires that only symbols from glibc <= 2.5 are used. All packages in the python package index must follow that policy, even though the glibc part is currently not automatically enforced. This affects e.g. [milksnake](https://github.com/getsentry/milksnake) and [pyo3](https://github.com/PyO3/pyo3). A newer requirement, called [manylinux2010](https://www.python.org/dev/peps/pep-0571/#the-manylinux2010-policy) is worked on, but it stills require glibc <= 2.12.
In general it means that you can't use any modern ci server to produce widely compatible linux-gnu binaries. You always have to build in some ancient docker container instead.
### Versions
* `rustc -vV`: `rustc 1.33.0-nightly (8e2063d02 2019-01-07)`
* `cargo -V`: `cargo 1.33.0-nightly (2cf1f5dda 2018-12-11)`
* The quay.io/pypa/manylinux1_x86_64 docker container run cent os 5.11 (Final) with glibc 2.5
* The cent os 7 container is cent os 7.6.1810 with glibc 2.17
This issue a bit of a follow-up to #36826.
