Is it accurate to call this “increasingly immutable”? The space between HFs increases but its not really any less mutable. I’m not sure that a stable period of 8 years followed by a HF is really any more immutable than a HF every 12 months?
Edit: Not trying to pick holes in this - just trying to wrap my head around what “immutable” looks like, short of zero HFs.
My opinion, as of right now, is that hardforks should be seen as extreme measures, as they are in Bitcoin. I’m not a fan of having them standardized. Breaking consensus should be seen as a doomsday measure.
Nevertheless, as david mentioned, softforks and hardforks must be discussed together. It’s practically the same discussion.
If there’s any community member who has a really good grasp of Bitcoin’s history regarding this subject of forks, please do join the dev meeting or comment here. There’s much to know and learn, and many conclusions to draw.
Anyway, why does the stance towards softforks lean negative currently? Was there already a discussion about it?
I think this is obvious hard fork is unacceptable it should only be done in critical situations.
If you can’t make a soft fork, then you should make the hard fork the first and last time, which will make the soft fork smoother.
You must strictly prescribe the rules for the soft fork and never return to the hard fork again.
IMO hard forks should be avoided at all costs. This is one of the things that Bitcoin got right. A Hardfork is like an attack on the protocol- If you keep forcing consensus changes then eventually enough people won’t agree and you’ll permanently split the chain. Soft forks cause the same issues, however, they are less intrusive since an upgrade is not mandatory.
The more immutable a coin is the more valuable it is.
I sit on the fence as to whether or not I want to use Grin. If there is another hard fork, I am out. I trust bitcoin because I know exactly what kind of money I am getting and the rules never change. I trust the Federal Reserve a lot less because they have been playing with the rules for decades. Make a promise on what the rules are and stick to them. Have respect for the miners who maintain the security of the network.
If someone were to develop bidirectional payment channels using the NRD kernels available on testnet, and NRD kernels would be validated through peer review and audits, then how would you argue against activating them on mainnet through a hardfork?
