Hello,
I am running two docker containers for foreign API and owner API. But when I am trying to run the second container I am receiving such error.
thread 'main' panicked at 'called `Result::unwrap()` on an `Err` value: LmdbErr(Error::Code(11, 'Resource temporarily unavailable'))': src/libcore/result.rs:1009stack backtrace:
0: 0x5568db26475d - backtrace::backtrace::trace::h2309a19e9582c4ed
1: 0x5568db263882 - backtrace::capture::Backtrace::new::h93a1fac54c6e6f9e
2: 0x5568db1e4c80 - grin_util::logger::send_panic_to_log::{{closure}}::h71a59b48864f140f
3: 0x5568db325819 - std::panicking::rust_panic_with_hook::h8cbdfe43764887be
at src/libstd/panicking.rs:495
4: 0x5568db3252c1 - std::panicking::continue_panic_fmt::h3d3c5a833c00a5e1
at src/libstd/panicking.rs:398
5: 0x5568db3251a5 - rust_begin_unwind
at src/libstd/panicking.rs:325
6: 0x5568db34241c - core::panicking::panic_fmt::h4d67173bc68f6d5a
at src/libcore/panicking.rs:95
7: 0x5568daa9fae9 - core::result::unwrap_failed::hdc7c65df7b1a45ba
8: 0x5568dab43ef6 - <grin_wallet::lmdb_wallet::LMDBBackend<C, K> as grin_wallet::libwallet::types::WalletBackend<C, K>>::set_parent_key_id_by_name::h9cae5c2fe44118f2
9: 0x5568daa4a0c7 - grin_wallet::instantiate_wallet::h8e4e9b1e745767e9
10: 0x5568daab364d - grin::cmd::wallet_args::wallet_command::{{closure}}::h132e0b3a03180ee7
11: 0x5568daaadd33 - grin::cmd::wallet_args::wallet_command::h0350a607ec147821
12: 0x5568daa72f3a - grin::cmd::wallet::wallet_command::h54a1611c558d3101
13: 0x5568daadb8f0 - grin::real_main::h656a99d0edd665a2
14: 0x5568daad9f15 - grin::main::h2a3a929d155af59c
15: 0x5568daac80d2 - std::rt::lang_start::{{closure}}::h1c9ba22e17ffb96f
16: 0x5568db325142 - std::rt::lang_start_internal::{{closure}}::hdfc28107b5be47c9
at src/libstd/rt.rs:59
- std::panicking::try::do_call::h69790245ac2d03fe
at src/libstd/panicking.rs:310
17: 0x5568db33b749 - __rust_maybe_catch_panic
at src/libpanic_unwind/lib.rs:102
18: 0x5568db325b13 - std::panicking::try::h9c1cbc5599e1efbf
at src/libstd/panicking.rs:289
- std::panic::catch_unwind::h0562757d03ff60b3
at src/libstd/panic.rs:398
- std::rt::lang_start_internal::h540c897fe52ba9c5
at src/libstd/rt.rs:58
19: 0x5568daadc331 - main
20: 0x7f90b83c12e0 - __libc_start_main
21: 0x5568daa21e40 - <unknown>
22: 0x0 - <unknown>
When I run containers separately they work ok, also, they work ok when I run API listeners without docker containers. Does anyone familiar with this issue?
