Keep sharing my grin coin family mine,grin coin does not die(
继续分享我的grin币家庭矿场,古灵不死。)
I dismantled the G1 36g and G1 mini shells, and then organized a group of 10 units in series.There are some G1 minis left that have not removed the shells, and the G1 36g is all modified.In fact, it is more suitable for the computer room with a good operating environment。
Advantages: better heat dissipation, more stable operation
Disadvantages: too much dust, poor home environment, easy to get wet.
The total grin mining power is more than 300 G, but it currently only runs one-sixth of the equipment. Part of the reason is that the equipment is broken and needs to be repaired; Another reason is that the grin coin price is not good, and there is no motivation to run all of them.
As long as we continue to mining grin Coins, the grin coin will not die.
我将一些G1 36g和G1 mini,拆掉外壳,然后10个左右组织一组串联一起,剩下只有一些没有拆掉外壳的G1 mini,G1 36g全部都改装了。
优点:散热更好,运行更稳定
缺点:灰尘太多,家里环境不好,容易受潮。
总算力有300多G,但目前只运行6分之一的设备。一部份原因是设备坏了,需要维修;另一个原因是币价不行,没有动力全部运行。
