Grin community on Nostr
Let’s share our nostr public keys (npubs) here.
If you don’t have an account yet, you can create one by using the following clients.
Android: Primal, Amethyst
iOS: Damus
Desktop: Gossip
Note that you will be connected to several nostr relays running by individuals and thus exposing your IP address to them. If you are not okay with this you can use tor (orbot) or any other VPN to hide your IP. On mobile, you can setup the orbot for proxying nostr client only, this way you are not slowing all your other apps because of the tor connection.
Also, Primal let you use their caching service (turned off by default), so you can expose the IP address to Primal exclusively.
npub1hw0s9g0u0jpcfezfvcyn86k0k9v0m3x8uj5cr7va478lksysyj6qzl59hh
npub1rs8hjnnwakggghdpugnz79n493mzl06kvar59cwylk37pe2txkjsc98lrw
I will follow! I can finally come out of the grin closet with strength in numbers lol
If anyone uses Bluesky, there’s an account promoting Grin over there as well: @mwgrin.bsky.social on Bluesky
npub1aa0jg6lpdkv7mu5k36ftf53ychyd06p9w4du98gjhts8nwt5jkgswsa386
transatoshi@snort.social
Primal? I remember someone complained about similar issue.
If you on Android try Amethyst client.
If on iOS, Damus is the best client.
Nostr protocol is very much WIP at the moment, so expect issues there.
But if you think that you can freely communicate over tor with a client of your choice without anyones permission and ads, then all these constraints became not that important and should be fixed over time.
Still not sure about Nostr though and if it could be adopted with the current protocol design, but it’s better than centralized social networks anyway.
Yep, was on Primal first and tried Amethyst and both were fucking up.
Snort is working great though, can follow just fine, so I purchased a Nostr ID through them.
This npub gets no results on both the Snort app and nostr.directory
Maybe because it has zero posts.
But both Amethyst and Primal can find it for me.
Ok, perhaps since I am connected through tor and not online most of the time.
When I first followed your npub on primal, it was a blank account yeah. But now it’s fully populated. I think it just takes a bit for their cache to update
