ASICs and Governance
First off, I was talking about RandomJS.
But while we’re talking about Cuckoo Cycle, although the verifier is simple, the solver is not, so that snippet is a straw man argument.
There’s no proof that factoring primes is hard, either, but at least there’s been tons of research around it. I wish more coins would use time-tested algorithms rather than newly invented ones, although new unproven PoW’s do present nice opportunities for people like me.
As for the claim that publicly available miners are the fastest, maybe maybe not. From a game theory perspective, you have to estimate a hack rate from public release and balance that against income from private licensing. From an anecdotal perspective, I have heard of faster miners in large private deployments, but haven’t personally verified this myself. Who knows?
IMHO the best a coin can do is use a well-known algorithm with proven bounds and known-optimal solver. Implementations will always vary, but with proven bounds the differences would be small.
If you’re really interested in an answer then here’s my opinion. I think it’s about some level of inclusivity. When the ASICS come, GPU miners are outcompeted off mining altogether. With the GPU farms they can still mine. In Grin’s case this is a new coin. If bitcoin started out with ASICS I doubt it would be where it is today.
Sure, it’s a good point. But you can buy an ASIC and run it at home just as well as you can buy a GPU and run it at home. No matter what, there’s economy of scale at play, and you’ll never get industrial power rates at a residence, regardless of your equipment.
For some, I think it’s just that they perceive BitMain as a monopoly. While that has been mostly true in the growth phase of cryptocurrency, I don’t see it continuing for very long. I certainly know of many new ASIC miners in development over the last year or so. We’ll see…
Here’s the essence of the lean solver, using two bitmaps, alive for the edge, and nonleaf for the nodes:
void count_node_deg(u32 uorv) {
  for (edge_t nonce = 0; nonce < NEDGES; nonce++) {
    if (alive(nonce)) {
      node_t u = sipnode(sip_keys, nonce, uorv);
      nonleaf.set(u);
void kill_leaf_edges(u32 uorv) {
    if (alive(nonce)) {
      if (!nonleaf.test(u)) alive.reset(nonce);
  for (u32 round=0; round < trims; round++) {
    for (u32 uorv = 0; uorv < 2; uorv++) {
      memset(nonleaf.bits, 0, nodeBytes));
      count_node_deg(uorv);
      kill_leaf_edges(uorv);
It’s just setting and testing random bits.
Factoring primes is trivial; their only factor is themselves:-)
There’s been a ton of research of graph connectivity also.
Many years of engineering competition is what made SHA256 differences small. The same can happen for a PoW based on the memory IO bottleneck. At the same time it can drive advances in memory technology.
Scrypt is a well-known algorithm with proven bounds and known-optimal solver, but it makes a pretty poor PoW, being very complex, and slow to verify.
Wow this is such a long topic and the foundational issues don’t even seem to be understood. ASICs are not the enemy of decentralization or privacy or security, they are just faster miners. They offer a fixed improvement over GPUs, in general, that won’t change. Pools on the otherhand are the actual existential threat to the ecosystem. Pools render all these decentralized miners into a centralized voice, that often the actual miner doesn’t even understand. Don’t focus on ASIC resistance while totally overlooking the move threatening and real danger that pool based mining represents for any cryptosystem. I even like pools, and use them sometimes, but they are actual the new central authorities we’ve built to replace our old ones, for no good reason.
Sam, I think you are completely right.
I’d like to mine with my CPU (of course for zero or even negative profits) but I can only make 0.1 GPS and I have been told, by experts users on the Grin chat, that my only real option is to mine for a mining pool, as opposed to solo mining.
In no way I am moving critics to anybody! But yeah, that’s a bit bizzarre precisely for the reasons you said. Centralisation occurs mostly because of the huge mining pools.
With a CPU you will very likely never mine a single block in the entire GPU friendly PoW existence, when lottery mining that is. Using a pool that actually has a chance to find a block is not an expert advice, it is common sense. Up to you to pick a small one and not the one that has 40% of the hash-rate.
@sam What is your solution then? I’m not sure I got that from your post. To focus on open source pool code that anybody can run instead of stuff like wallet development?
There is already open source pool code there is going to be a lot of competition; much easier to spin up a pool than a centralized mining farm.
For someone mining at a loss (e.g. CPU mining), a pool simply makes it a guaranteed loss, while solo mining makes it only an expected loss, like a lottery.
Therefore I’d say only solo mining makes sense…
Thanks for the suggestion.
Actually, with 0.1GPS I can test about 6 Graphs/Minute, correctly?
This gives me some possibilities (even if remote) of solo-mining a block right?
For some reasons I think i misunderstood the suggestions i received in the chat,
and I understood that with 0.1 GPS I had no chances at all.
But anyway, just to understand better: is it correct that if somebody can mine, e.g., 0.9 GPminute, than it makes zero sense to solo mine?
Thanks in advance for any further suggestions/discussion !
You would have non zero chance even with 0.8 graphs per minute, because not all blocks are found exactly after one minute. Given the near zero chance to start with, it would not change your chances in any measurable way. As a form of gambling, it is fine.
